Maier ITF - first failure?!
Has thanked: 7 times
Been thanked: 48 times
Post by Merlin66 » Tue Apr 03, 2018 5:12 am
I, like many others, have replace failed Coronado ITF filters with the Maier ITF.
Over the years I've been very happy and impressed by the Maier performance.
Well, this morning I was presented with my first Maier failure......
The central 40% is "burnt out" - not easily visible from the bright front surface but very noticeable when inspecting the rear of the filter.....
(This is a "H-alpha ITF Blocker -ITF0143# 1")
Has anyone else experienced failure of these ITF???????
GUS
Has thanked: 1 time
Been thanked: 2 times
Re: Maier ITF - first failure?!
Post by GUS » Tue Apr 03, 2018 6:35 am
That's interesting Ken, any pictures?
Post by Merlin66 » Tue Apr 03, 2018 6:45 am
A couple of quick images.
First the rear surface against a bright background.....
Rear surface
Rear surface
The front surface....difficult to see the failure.
Front surface
Front surface
GUS
Has thanked: 1 time
Post by GUS » Tue Apr 03, 2018 6:55 am
Looks like the Beloptik might be a better option, hard coatings on KG3 and RG630, cost a bit more, and the whole filter diameter is utilised, you don't need the O ring.
Post by Merlin66 » Tue Apr 03, 2018 10:24 am
My money would be on a Baader 35nm Ha CCD filter at the front of the blocking filter diagonal.
(No O ring was used in this fitment.....)
GUS
Has thanked: 1 time
Post by GUS » Tue Apr 03, 2018 10:59 am
I tried the Maier originally, but replaced it with the Beloptik ITF for one BF and a Baader 35nm plus a Beloptik KG3 with IR/UV cut for the other.
Post by Merlin66 » Tue Apr 03, 2018 11:05 am
You don't need any secondary filters with the Baader.....it gives good cut-off as is.
(I've used the UV/IR KG3 filter on it's own as an ITF......OK but I prefer the Baader solution.)
Just interested... why did you replace the Maier ITF??
GUS
Has thanked: 1 time
Post by GUS » Tue Apr 03, 2018 11:32 am
I use my Coronado BF's with my Lunt scopes. The Maier filter had too much background glow, plus the O ring wouldn't fit which left an exposed bit of filter around the circumfrence. In comparison, the Beloptik filter image looked a lot cleaner without too much glow. Interesting about the Baader, I remember seeing a thread on here regarding the Baader not being sufficient as a stand alone ITF for visual. I know with the Lunt ERF which is RG610 that I can use the KG3 without the Baader.
Has thanked: 1951 times
Been thanked: 759 times
Post by marktownley » Tue Apr 03, 2018 7:57 pm
I guess laminated filters are always going to fail sadly :(
Post by Merlin66 » Tue Apr 03, 2018 10:29 pm
Gus,
I don't believe there are any safety issues using the Baader 35nm filter as an ITF.
I use the the "big brother" D-ERF version on my PST Mod.......
Has thanked: 27 times
Been thanked: 106 times
Post by Valery » Sun Apr 08, 2018 2:36 pm
Gus,
According to my experience the KG3 is essential. 35nm Baader alone as an ITF is not enough.
Post by Merlin66 » Sun Apr 08, 2018 4:46 pm
Valery,
What exactly have you found that the KG3 gives that the Baader doesn't?
As tested with the spectrograph, there should be no issue.
DavidG
Post by DavidG » Tue Apr 10, 2018 10:01 pm
Both of my Maiers filters are still perfectly clear and my two are the first two he made.
- Dave
