AR from July 12
p_zetner
AR from July 12
Post by p_zetner » Fri Jul 13, 2018 5:04 pm
Greetings Everyone.
Some views of the current AR at two different image scales.
(Please excuse the dust mote on the higher magnification image. I didn't flat-field this one and don't have access to Photoshop at the moment!)
Cheers, Peter.
p_zetner
Re: AR from July 12
Post by p_zetner » Fri Jul 13, 2018 6:40 pm
Also, a very small AR near the W limb that seems to have disappeared.
I just discovered this as seeing started to seriously degrade so the imaging was pretty bad.
Cheers, Peter.
Re: AR from July 12
Post by eroel » Sat Jul 14, 2018 12:23 am
Peter:
Very very good images with your 8" scope, you are getting better shots every day.
I am anxious to start using my 10" f/20 Maksutov with an Aries ERF, but weather and compromises during weekends have not let me go to the rural observatory.
Have a nice and sunny weekend,
Re: AR from July 12
Post by Carbon60 » Sat Jul 14, 2018 5:49 am
Nice images, Peter. Getting better and better.
Lunt LS60THa B1200 PTFT
DMK41, Basler acA1920-155
NEQ6 Pro-mount
Re: AR from July 12
Post by ffellah » Sat Jul 14, 2018 12:16 pm
Beautiful, sharp looking images, Peter !
Re: AR from July 12
Post by marktownley » Sat Jul 14, 2018 1:42 pm
Very good Peter! The flat field function in firecapture works great for close in shots like these, all you need is some plastic film big enough to cover the aperture of the scope.
Re: AR from July 12
Post by Valery » Sat Jul 14, 2018 3:39 pm
Nice images, Peter
I think that the middle scale between the two shown will be the best compromise details/sharpness wise.
p_zetner
Re: AR from July 12
Post by p_zetner » Sat Jul 14, 2018 8:51 pm
Thank you for your comments, everyone.
Eric: I hope you get the chance soon to try your 10" Mak. I look forward to seeing images from this instrument.
Stu: I'm totally impressed by the granulation shots with your 250mm RCT. Hope you have some luck with H alpha.
Mark: I flat-field the images involving my focal reducer because there is a hot spot present in the field of view. The field homogeneity without focal reduction is quite good but, of course, doesn't solve the dust bunny problem! Flats next time.
Valery: Good advice! This was a rather large structure. I'll have to experiment with slightly different FR design to get around f35 - f40 at the camera.
I'm back at my Photoshop equipped computer so can remove the obnoxious dust spot. Here is the result of the high magnification image with slightly different (better?) processing.
Cheers, Peter.
Re: AR from July 12
Post by Montana » Mon Jul 16, 2018 1:57 pm
These are really nice Peter :bow
p_zetner
Re: AR from July 12
Post by p_zetner » Mon Jul 16, 2018 6:30 pm
Thanks very much, Alexandra. Still experimenting with processing!
Cheers, Peter.
Users browsing this forum: No registered users and 15 guests
