A quick post about a revision I made to my modded Celestron CR-150 OTA/Lunt DSII etalon mod.
I have been wanting to set up a double stack on this system but never had a lot of time to pursue it...had been thinking of trying a Quark but wasn't prepared to shell out the cash without knowing if it would work.
What I wound up doing was hiving a local machinist make a threaded adapter to allow mw to mount the primary Etalon out of my LS80T at the rear of the donor OTA, and then install the DSII module for a DS system. I had a very short window to assemble and test yesterday over the noon hour...terrible seeing and strong winds made for an interesting first light.
The layout is shown below...from right to left: CR-150 OTA (internal Baader ERF)/Primary LS80T Etalon (red)/DSII module (black)/Moonlite focuser/B1800Ha blocking filter/Explore Scientific 3x Tele-converter/Daystar tilt adapter mounted to the ZWO ASI174MM camera: First are a few images in the single stack mode: In the DS mode it does improve the contrast: Just a few points on the images...no flats (some dark banding in the DS images) and no alignment checks due to time limits. I just assembled the pieces and shot the test frames before I ran out of time. To seal the trial off I had clouds roll in until I was back to the office
Waiting on another sunny day to test things out some more.
Questions and comments are welcome...how do the modders in the group see this???
Another pending Mod is to fit the DSII to the C9.25 Edge as a single stack. A trial looked promising but my temporary housing wasn't rigid enough to stop the flexure. I'd like the ability to run this and use the pressure tuning to do quick on-band/wing images and when the seeing is good switch to the Quantum for the more narrow bandpass work (0.45A).
Thanks,
