New Skybender tilt modules - 1.25" and 2"
TheSkyBurner
Post by TheSkyBurner » Fri Oct 12, 2018 10:44 pm
I was just informed of a package delivery containing 10 new Skybenders. The manufacturing order for these was made in march of 2018 and delivery was just recieved.
If you would like a 1.25" Skybender - $160 shipped worldwide *7 left* (10-15-2018)
if you would like a 2" Skybender - $175 Shipped worldwide (sold out as of 10/13/2018)
paypal Apollo @ amplelight dot com
International buyers are encouraged!
You can see what things Skybender is capable of here. viewtopic.php?f=9&t=24440&p=220932#p219630
I have given 2-dozen Skybender's away for free in the last 5 years, delivered all over the world. Now this is the last of them and I will not be having anymore made. I will soon be stepping aside from astronomy due to unfortunate life circumstance's.
A special Thank's to all who have participated with Skybender!
TheSkyBurner
Re: New Skybender tilt modules - 1.25" and 2"
Post by TheSkyBurner » Sat Oct 13, 2018 8:12 am
1.25" skybender has a standardized 2" top thread that Can be threaded onto SCT's rear cell. It can also be fitted to the baader planetarium click lock diagonal using the baader planetarium SCT inverter #1508020
https://www.baader-planetarium.com/en/b ... hread.html
https://www.baader-planetarium.com/en/b ... irror.html <-------IR/UV rejection mirror made for solar filters!
two 1.25" Skybenders can also be stacked together with the same baader planetarium 1508020 inverter for a double tilt module.
TheSkyBurner
Post by TheSkyBurner » Sat Oct 13, 2018 8:20 am
the two inch skybender allows more room to work with. It has a 2" tilting cell, and it is large enough to integrate several filters directly inside of the nose piece.
Post by Valery » Sat Oct 13, 2018 9:44 am
PM sent.
Post by MalVeauX » Sat Oct 13, 2018 12:57 pm
These are great, I have two and can say they really are well made devices.
The 2" version can be made into an entire optical system that is modular. You can put a filter on the nose, add a nose extension, put two filters in the tilt cell (one on each side) and filters on the eyepiece side. I configured it to have two ERFs and two narrowband filters as a single device. Very versatile!
Thanks Apollo!
Here's my blue one with two ERFs and two narrowband filters that is simply inserted into a refractor (up to 150mm tested). Compact and modular.
TheSkyBurner
Post by TheSkyBurner » Sat Oct 13, 2018 2:35 pm
All 2" models are now soldout .
There are only seven 1.25" left.
p_zetner
Post by p_zetner » Mon Oct 15, 2018 7:58 pm
Hi Apollo.
From what I can gather, the 1.25" Sky Bender has a female SCT thread on one side and a 1.25"OD tube on the other?
Please confirm this if you can.
Thanks.
Peter
