Where to go from here to maximize results (Histogram, etc.).
Starry Jack
Post by Starry Jack » Thu Nov 08, 2018 1:53 am
I have successfully created my 152mm Stage One Mod. I purchased an ERF from Val (Aries) and I love it (anybody want to buy my Lunt 100mm ERF?).
While I am pleased with the results, they are nowhere near what I am seeing others produce so I suspect there is more for me to try with your coaching OR...the really pretty photos are all accomplished in post processing.
EQUIPMENT:
-152mm achromat
-Val's Aries 150mm external ERF (homemade cell out of $4 in wooden knitting hoops!)
-->Glasspath 1.7x in front of the PST Etalon
-->PST Black Box with Standard 5mm BF
-->Baader 1.25" UV/IR Cut filter (Val recommended the Astronomic LV1 but I already own the Baader...let me know if the results should be superior with the Astronomic)
-->Mallincam AG 1.2C camera
* Sony IMX224 CMOS sensor (class 1)
* Sensor Sensitivity: 2350 mv
* 3.75X3.75 pixels size
* 1280 X 960 resolution and 640X480 resolution mode
* 1.2 Mp sensor, 1/3" size (6 mm) diagonal
I have a different camera, but until I can make the Stage 2 mod, I am limited to the Stage 1 1.25" nosepiece holder on the PST.
Given the above:
1) What should the histogram look like? Where do I want to spread my values on the left or right or where do I want the peak?
2) Where would you suggest GAMMA? I see noise with higher gamma but better contrast.
3) Where would I want CONTRAST and BRIGHTNESS?
I have attached a video to show you might first light. I have also attached screenshots of the HISTOGRAM and other SETTINGS (lots of poor seeing that day).
152mm Stage One PST Val ERF.mp4
(213.01 KiB) Downloaded 35 times
HISTOGRAM SETTINGS 3.png (1.2 MiB) Viewed 1254 times
HISTOGRAM SETTINGS 2.png (1.34 MiB) Viewed 1254 times
HISTOGRAM SETTINGS 1.png (1.35 MiB) Viewed 1254 times
Jack
Aeries D-ERF
Huge Sense of Adventure viewing Creation
Re: Where to go from here to maximize results (Histogram, etc.).
Post by MalVeauX » Thu Nov 08, 2018 3:48 pm
Image in B&W (mono), no need to capture color data here. And then just look at your histogram in monochrome. That will help with simply judging things with the histogram, since imaging in color is going to show a lot more red channel than green or blue. It won't change the sensitivity, but it does make the histogram easier.
Regarding the histogram, I fill the histogram to the right just enough to not clip data. This is to get as much signal as possible recorded without losing data. I image with 200+ gain sometimes. Don't be afraid of noise. It mostly stacks out anyways (random noise does). I will go as slow as 10ms for exposure time on full discs and small scale imaging. But at higher resolution and larger scale, my minimum is 5ms exposure time, and shorter is better (2ms, 3ms, etc). For the surface, don't use any gamma, leave it neutral. Just fill the histogram. For prominences, I do use gamma (maximum value) with the same filled histogram. I capture both the surface & proms in one capture with maximum gamma use too. There's several ways to do it. But starting out, I would just focus on the surface and use no gamma (neutral) and get used to filling the histogram.
I don't use FireCapture, so I cannot really suggest much with the settings beyond basic exposure values and gamma use. I do not recommend using any of its internal processing as it's not likely as good as a good pixel editor (photoshop for example). But take that with a grain of salt, as I'm using SharpCap. I just get the RAW data and fill the histogram. I don't do any editing with brightness, contrast, etc, in the capture phase, I do that separately after I've stacked the data and have a good file to process.
I can't tell if you're in focus, or if seeing is really bad. So you'll have to confirm it's reaching focus appropriately, versus just bad seeing.
Here's how my histogram looks, filled without clipping data, in mono:
Starry Jack
Post by Starry Jack » Thu Nov 08, 2018 4:05 pm
Gents,
Thank you both for your input. I will fiddle with the Glasspath, but there are moments of good seeing in a video clip which indicate a sharp focus.
Most of my work is live video outreach so post processing is a luxury when I have a moment using Registax. I'D LOVE some pointers on Registax as well since I have blown away the settings I liked and can't seem to recreate good stacking to save my life.
Marty,
Your histogram advice is EXACTLY what I was looking for. Good stuff and I will practice immediately (sun permitting). I use the Mallincam Sky software designed for their cameras (some of the folks do use Sharpcap as well) rather than FireCapture. Regarding focus, the screen grabs above simply moments of poor seeing, but if you click on the MPG link you see when it snaps into decent focus.
Best,
Jack
Aeries D-ERF
Post by MalVeauX » Thu Nov 08, 2018 5:05 pm
Hi Jack,
Yea, the video illustrates a much better image than the screen captures, thanks!. Still looks like either really challenging seeing, or perhaps not at critical focus to me though. But again, hard to know, a short video.
I think the obvious limitation here is likely the tiny blocking filter of the PST. It's robbing you of transmission and giving big vignetting. I would look into upgrading to a Stage II soon with a 15mm Coronado blocking filter. It would make a significant difference in general for everything.
I think FireCapture has an option for real-time flat calibration, which would be super helpful for live streaming outreach to remove dust motes and gradients and vignetting. I would look into this, especially for your purposes.
I've attached some examples with a histogram as above, the actual footage (forgive me if I killed the detail compressing it, but uploading 4gigs of video as 10Mb probably took away from the quality for sure, but, if you watch around 20seconds, the seeing improves and you can see individual spicules, so some good seeing in moments and definitely in focus). Attached also a stacked result of that video. And a colored version.
RAW video (compressed obviously though) (look around 20~25 seconds):
Example_Seeing_Focus_Chromosphere.mp4
Seeing improves around 20 seconds in, example of spicules, real time seeing
(9.57 MiB) Downloaded 35 times
Example Flat Frame (defocused with the disc filling the FOV):
Example of a flat frame
Stacking results & histogram (no processing yet):
Example of stacked unprocessed image with flat calibration with histogram from the RAW video
Processed the Stacked Image (a little histogram stretching, contrast and sharpening/deconvolution):
B&W stacked result with minor processing
False colored
Starry Jack
Post by Starry Jack » Thu Nov 08, 2018 5:42 pm
Marty,
I love the progression of the raw video and the post processing. That is really helpful to gauge where I am. I am encouraged.
Regarding the Glasspath...I can't wrap my brain around where to place it. It is currently sitting on top of the etalon so I cannot move it closer to the BF. However, the BF is spaced according to the PST Black Box. If the beam is f6.5 and the Glasspath is 1:1.7, how do I figure the math for placement?
Can I ask for your workflow in your stacking program?
Spending money on Val's ERF means no Stage 2 mod for some time but a guy can dream!
Jack
Aeries D-ERF
Post by MalVeauX » Thu Nov 08, 2018 6:02 pm
Hey Jack,
Hopefully someone else can chime in about your optical train to make sure an F10 or more narrow beam is hitting that PST. It doesn't have to be exactly F10, it just cannot be faster than F10 (ie, it cannot be F6 or F8). F10 is where it's supposed to be. And I think it's fine to go to F12 or even more narrow and it will still work fine (just dimmer image, but probably will tighten up bandpass a bit too if I recall correctly).
Work flow from above:
RAW video acquisition via SharpCap with histogram filled to around 90% or so, filled but not clipping data.
Defocused video acquisition to create a flat frame from the disc filling the FOV (not on a limb) at same exposure value.
Flat frame created in Autostakkert!2 with the defocused video.
Flat frame loaded on the RAW video in Autostakkert!2 and analyzed.
I stacked 60 of the best frame from the 2,000 that were in that video.
I load the stacked result in IMPPG and do a little histogram stretch and some deconvolution (sharpening).
I load the resulting image from IMPPG into Photoshop for final edits.
Final edits are just a levels adjustment to increase contrast; contrast adjustment; high pass filter x 2 (sharpening) and a light unsharpen mask (sharpening).
Coloring is done with levels adjustment.
Starry Jack
Post by Starry Jack » Fri Nov 09, 2018 4:29 am
Thank you for the workflow, Marty. Makes sense. In fact, you've got me going back to Autostakkert again.
Attached is the video going through one of my trials in Autostakkert this afternoon. Much improved. Room for more to be certain.
Stack 29 Noise 4 Last Stack_0001_g4_ap331_conv SMALL.png (1.2 MiB) Viewed 1162 times
Aeries D-ERF
Post by MalVeauX » Fri Nov 09, 2018 12:27 pm
Looking good!
Post by Valery » Fri Nov 16, 2018 2:16 am
Hi Jack,
I would advice the following imaging train.
ARIES DERF - 6" refractor - 1,25x - PST Mod1 - Barlow lens - camera.
For 5.86m pixel camera chip you need about F/20 - F/28
if the pixel size is smaller, you need a proportionally smaller F/D.
For prominences use smaller F/D - depends of how bright or dark they are.
The very first step is not a Mod-2, but a b/w camera. Here is your greatest potential.
I would suggest a ZWO ASI290MM or similar.
When you fine tune your etalon, make sure it shows on the screen a round dark spot at the
center of the FOV. Try to make this "sweet spot" as larger as possible. This is the area
where your system works in H-a.
When recording the movies, do use the ROI - right around the sweet spot.
Use the gamma setting which shows you most details on the screen.
Starry Jack
Post by Starry Jack » Fri Nov 16, 2018 2:40 am
Thank you, Val!
And I did get your email and will send photos of the cell and results. I also appreciate your encouragement.
The camera is 3.75x3.75 pixels. The Glasspath is 1:1.7 and I can't change that right now. I can shoot in grayscale, however, there is not as much enjoyment there for me since I mostly do live outreach and only when I have the luxury of time do I do some stacking in Autostakkert or Registax.
I really appreciate the guidance on the sweet spot and ROI. That makes good sense to me. I'll also try the Barlow again tomorrow if we have sun. I will also keep the gamma high as you suggest (I do see the best contrast in that range).
I think my system is f22 with the Barlow (f6.5 x 1.7 Glasspath = f11.05 x 2x Barlow) = f22.1. Is my math correct?
Jack
Aeries D-ERF
Starry Jack
Post by Starry Jack » Fri Nov 16, 2018 2:45 am
TheSkyBurner,
I never thanked you but...THANK YOU for taking the time to look up the thread counts and where to buy the "cheapo" adapter. That was very good of you. :)
Jack
Aeries D-ERF
Starry Jack
Post by Starry Jack » Fri Nov 16, 2018 3:36 am
Earlier it was mentioned that I could move the position of the Glasspath further from the etalon. I thought the Glasspath simply converts the beam to straight therefore no impact to F/D. Am I incorrect? Should I move it a bit further from the etalon?
Jack
Aeries D-ERF
Starry Jack
Post by Starry Jack » Fri Nov 16, 2018 6:29 pm
VICTORY!!!!
Now THIS is getting better! Here is a grayscale capture and a color capture, 13 best frames out of 80 (short video) in Autostakkert.
Barlow brings the system to f22. No ROI needed since there was no "sweet spot" using the Barlow and Val's instructions.
Many thanks to all for your guidance.
Now on to improve, improve, improve. And to eradicate those dust bunnies.
Jack
Aeries D-ERF
