New version of ImPPG
Has thanked: 17666 times
Been thanked: 8787 times
I downloaded the new version of ImPPG but all the buttons at the top are black? I have to hover over them to read which button is which. Is this a bug?
Has thanked: 20424 times
Been thanked: 10243 times
Re: New version of ImPPG
Sounds like a glitch to me.
Has thanked: 173 times
Been thanked: 615 times
Post by Merlin66 »
Alexandra,
Just downloaded the latest version and it works OK for me...
Video settings??
GreatAttractor
Has thanked: 747 times
Been thanked: 753 times
Post by GreatAttractor »
Alexandra, which Windows version do you use?
Did you perhaps unpack ImPPG to a folder containing the previous version? If so, try unpacking to a fresh folder and running from there.
My software:
My images
Thanks, I have Windows 7.
I will try and download again tonight. I did it at the same time that I messed up FlyCapture and had to do a system restore. Maybe this has affected it somehow.
Radon86
Has thanked: 745 times
Been thanked: 660 times
Post by Radon86 »
Hi Alexandra,
I only downloaded the latest version 0.5.4 only yesterday. I have a Quark Chromosphere filter, only used once so far, for my ED70 refractor.
Here is my ImPPG started up:
I think the icons image files are missing, maybe there was an error in the unzipping.
Magnus
Just fixed - broken item number 1 :hamster:
I had 3 part versions in the 32 program folder. Everything must have got messed up with the system restore. I removed all the junk, downloaded the version again and placed the folder in the 64 bit program folder. Yippee it works!!!
Only 3 more broken things to sort now
