remote focussing added to scope
skyhawk
Post by skyhawk » Tue Apr 02, 2019 12:15 pm
I am NOT good at describing things so I have attached images, the FINAL belt used to drive the focusser from the Skywatcher unit
http://www.opticalvision.co.uk/astronom ... cuser.html
attached to the actuall scope focusser via home made (as I couldn't find one the right size) belt, from a cut down vacuum cleaner belt
https://www.amazon.co.uk/gp/product/B00 ... UTF8&psc=1
and shaped cycle inner tube repair kit
Now with 30' of leads it is easy to image from indoors
72mm Ed Skywatcher for Solar
SkyTee 2
Sky-Watcher SolarQuest
Gitzo Systematic Series 5
ASI 178MM
Daystar Quark Ha
WO Binoviewers
Many eyepieces 2"
Re: remote focussing added to scope
Post by marktownley » Tue Apr 02, 2019 2:24 pm
Looks good! I've popped this in the mods section as is better suited there.
skyhawk
Post by skyhawk » Tue Apr 02, 2019 4:46 pm
Many thanks
SkyTee 2
ASI 178MM
Daystar Quark Ha
WO Binoviewers
Many eyepieces 2"
skyhawk
Post by skyhawk » Tue Apr 02, 2019 4:49 pm
Now the scope looks a complete mess :) :)
SkyTee 2
ASI 178MM
Daystar Quark Ha
WO Binoviewers
Many eyepieces 2"
Rusted
Post by Rusted » Sun Jun 02, 2019 3:47 pm
I hope you have better luck with your focuser motor, control paddle than I did. Mine rapidly flattened the first 9V battery.
It then ran continuously one way but completely ignored releasing the active button and totally ignored the other button.
The little motor and housing is neat so I may bypass the useless control paddle. I only need maximum speed anyway.
A simple rubber band or thin O-ring makes a suitable drive belt. It also allows the focuser to be manually adjusted without removing the belt.
