I am NOT good at describing things so I have attached images, the FINAL belt used to drive the focusser from the Skywatcher unit
http://www.opticalvision.co.uk/astronom ... cuser.html
attached to the actuall scope focusser via home made (as I couldn't find one the right size) belt, from a cut down vacuum cleaner belt
https://www.amazon.co.uk/gp/product/B00 ... UTF8&psc=1
and shaped cycle inner tube repair kit
Now with 30' of leads it is easy to image from indoors
remote focussing added to scope
72mm Ed Skywatcher for Solar
SkyTee 2
Sky-Watcher SolarQuest
Gitzo Systematic Series 5
ASI 178MM
Daystar Quark Ha
WO Binoviewers
Many eyepieces 2"
SkyTee 2
ASI 178MM
Daystar Quark Ha
WO Binoviewers
Many eyepieces 2"
- Has thanked: 20813 times
- Been thanked: 10485 times
Re: remote focussing added to scope
Looks good! I've popped this in the mods section as is better suited there.
Many thanks
SkyTee 2
ASI 178MM
Daystar Quark Ha
WO Binoviewers
Many eyepieces 2"
SkyTee 2
ASI 178MM
Daystar Quark Ha
WO Binoviewers
Many eyepieces 2"
Now the scope looks a complete mess
SkyTee 2
ASI 178MM
Daystar Quark Ha
WO Binoviewers
Many eyepieces 2"
SkyTee 2
ASI 178MM
Daystar Quark Ha
WO Binoviewers
Many eyepieces 2"
- Rusted
- Has thanked: 8168 times
- Been thanked: 1943 times
I hope you have better luck with your focuser motor, control paddle than I did. Mine rapidly flattened the first 9V battery.
It then ran continuously one way but completely ignored releasing the active button and totally ignored the other button.
The little motor and housing is neat so I may bypass the useless control paddle. I only need maximum speed anyway.
A simple rubber band or thin O-ring makes a suitable drive belt. It also allows the focuser to be manually adjusted without removing the belt.
