AR12738 at High Res through 150mm refractor and QUARK Chromosphere.
Post by Valery » Fri Apr 12, 2019 1:30 am
Hi all,
April 11 morning was reither cloudy and foggy. However in two hours the sky cleared.
The seeing was average but with some improvements.So, I took my computer and Quark and
quickly set up the telescope.
Here is the best shot of the AR12738 I was able to take.
The telescope is SkyWatcher 150/750 equipped with the ARIES full aperture DERF, Quark Chromosphere and Basler ASA 1920-155 camera. A 2x TV PM barlow has been used to get F/43 at the etalon (remember that Quark has it's own build-in 4,3x telecentric barlow). F/43 at the etalon helps to keep etalon's bandwidth maximally narrow and so, best possible image contrast.
Thanks for looking.
JohnW
Re: AR12738 at High Res through 150mm refractor and QUARK Chromosphere.
Post by JohnW » Fri Apr 12, 2019 1:38 am
Good detail Valery. I saw this spot yesterday but its good to see it up close. Thanks, John W.
Post by Carbon60 » Fri Apr 12, 2019 5:28 am
Nice one, Valery. Lots of fine detail.
How many Quarks did you get through before you got a good one?
Lunt LS60THa B1200 PTFT
DMK41, Basler acA1920-155
NEQ6 Pro-mount
Post by marktownley » Fri Apr 12, 2019 5:45 am
This is an excellent capture Valery
yltansg
Post by yltansg » Fri Apr 12, 2019 5:47 am
Hi Valery,
That is a very nice image, despite the weather. I am also keen to try using a Quark Chromosphere on my Celestron 150mm Omni XLT fitted with an ARIES D-ERF. Do you use a 2" 2X TV barlow immediately at the output of the telescope followed by the Quark Chromosphere? Any other adapter/spacers required in between? Can you show a side-view picture of the telescope with the Quark and Basler camera?
Thanks.
Alfred
Post by MalVeauX » Fri Apr 12, 2019 4:59 pm
Lovely capture Valery!
Post by Valery » Sat Apr 13, 2019 12:55 am
Yes, correct. And no optics in between.
Post by MapleRidge » Sat Apr 13, 2019 3:56 am
That is an excellent image Valery...well done :bow
Post by Valery » Mon Apr 15, 2019 1:24 am
It's uniformity is far from perfect. Visually the non-uniformity is relatively easily seen, especially when moving accross the sun disk.
It is very narrow, but not really uniform,
MAURITS
Post by MAURITS » Mon Apr 15, 2019 8:05 am
Excellent Valery.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
Post by Valery » Wed Apr 17, 2019 2:41 am
Thanks, Maurits.
Post by Montana » Thu Apr 18, 2019 9:39 am
That's a cracker Valery :bow :hamster:
Users browsing this forum: pedro and 10 guests
