AR2740 with Bobs filters
RodAstro
Has thanked: 154 times
Been thanked: 171 times
Post by RodAstro » Sun May 05, 2019 8:51 pm
I have finally got an image I am pleased with using Bobs ebay filters.
The seeing was bad and I only got 30 mins before the sun hit next doors house.
The big problem I have had is vertical lines caused by the QHY5II-M seems a big problem with this camera.
So I orientated the image that it would drift across the lines with the drive motor speeded up and then when staked the lines will be in different places on the final image and they will not stack. I can then use Registax wavelets to bring out some detail. This worked a treat.
Not as good as a Quark but does work so now a Quark and D-ERF is next on my list when I have passed that past the boss :lol:
The image was taken with my Carl Zeiss Jana 150mm f15 Coude stopped down to 110mm f20.
Th filter system uses a 50mm UV/IR, 630 Red, Bobs blocker 25mm, Bobs (etalon) filter, KG3, Bobs second (etalon) filter.
No collimators or telecentric.
Camera QHY5II-M
Image is a stack of 20 frames 800x600 from 1000 at 25 fps using EZPlanetary, Staked with AutoStakkert, Registak Waves, Ps cs6 to finish.
5-5-19 5-30pm Zeiss 150 coude stop110mmf20 Bobs filters QHY5II M.jpg (64.83 KiB) Viewed 766 times
Has thanked: 2837 times
Been thanked: 1142 times
Re: AR2740 with Bobs filters
Post by marktownley » Mon May 06, 2019 9:17 am
Missed this one! Nice shot.
RodAstro
Post by RodAstro » Mon May 06, 2019 1:01 pm
Thanks Mark
For a while I never thought the filters were ever going to work.
But now I can see something I have the solar bug.
When I had one of the first PSTs I always thought about ripping it apart and was sure it would work but there was not enough info back then no one had done it.
What I have learnt from this project is that aperture beats f ratio with these filters, f30 is not needed, it works well at f15 when the seeing is good.
Also the more optics the more problems, keep it simple.
Next will be a Quark combo and hopefully a Baader D-erf then I may catch you up.
Has thanked: 2861 times
Been thanked: 1086 times
Post by Montana » Tue May 07, 2019 8:44 am
Nice image Rod, looks like you put a great deal of effort into this :hamster: :bow
RodAstro
Post by RodAstro » Tue May 07, 2019 6:42 pm
Thanks Alexandra
yes it has been a lot of work but interesting
It also works on proms quite well
16-49-38-897 21stack Corono wavelets crop PSP colour.jpg (92.44 KiB) Viewed 704 times
Post by marktownley » Tue May 07, 2019 7:37 pm
Nice addition with the proms
MAURITS
Has thanked: 19 times
Been thanked: 80 times
Post by MAURITS » Wed May 08, 2019 5:06 am
Well done Rod.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
