Blocking Filter In a Collimated Beam?
Has thanked: 20828 times
Been thanked: 10502 times
Anyone ever tried placing a Coronado / Lunt blocking filter in a collimated beam to see if it trims down continuum leakage in the wings?
bart1805
Been thanked: 1 time
Re: Blocking Filter In a Collimated Beam?
Post by bart1805 »
Interesting question Mark! Hope somebody has tested it. In addition to that question: what is the effect in theory of tilting the Blocking filter? Will try it out, but curious what to expect.
Has thanked: 174 times
Been thanked: 619 times
Post by Merlin66 »
I was thinking of another approach...
What about a blocking filter double stack to reduce the FWHM and trim the etalon wings.....
Post by Merlin66 »
Bart,
Tilting the blocking filter will move the CWL towards the blue, but won't change the FWHM result.
Bob Yoesle
Has thanked: 541 times
Been thanked: 811 times
Post by Bob Yoesle »
"Anyone ever tried placing a Coronado / Lunt blocking filter in a collimated beam to see if it trims down continuum leakage in the wings?"
Hi Mark, not sure this would get much improvement. If the BF has a Lorentzian profile - just as with FP etalons - the main effect would be to improve field angle rays through the filter so they are not as blue-shifted out of band (e.g. the filter's Jacquinot spot would be enlarged), but I don't think it would do much to change the filter transmission profile.
As Ken notes, double stacking a blocking filter would probably have a greater effect to reduce the etalon's wings. We can see for the one measurement I know of the Coronado blocking filter does appear to have a Lorentzian profile with a peak transmission of about 65%, and a FWHM of 0.6 nm.
For a single stack Lorentzian the 1% transmission value is 10 x FWHM = 6 nm, and for double stacking the 1% transmission value is reduced to 3 x FWHM = 1.8 nm. Not sure this would be too significant. However, double stacking the blcoking filter would reduce transmission to about 42%, which would be significant.
More discussion can be found here:
http://www.astrosurf.com/viladrich/astr ... ntrast.htm
Interesting thanks guys!
christian viladrich
Has thanked: 1 time
Been thanked: 2725 times
Post by christian viladrich »
Hi Mark,
The question of tilt / collimated or telescentric beam starts to become an issue with filters narrower than about 2 to 3 A.
BF are usually about 5 to 10 A. So, it should not be a big issue.
Regarding stacking an etalon and a BF, I've done many tests. For example here with a top quality 1.5 A BF and a variety of etalons :
http://www.astrosurf.com/viladrich/astr ... -tests.htm
A 1.5A BF would require a TEC body. If ever you are interested in it, you can contact me through PM.
Post by Merlin66 »
Christian,
Have you looked at double stacked blocking filters to trim the etalon wings??
christian viladrich
Has thanked: 1 time
No, I have not tested nor calculated it.
If I take the example of a SolarSpectrum or DayStar etalons, there is already a 5 to 10 A BF in the body of the filter
Adding a 4 A BF gives a little bit more contrast (see my test pages).
The real benefit is with the addition of a 1.5A filter. I also tested a 2 A filter which was good. Still the 1.5 A is better.
A 1 A would be still better. I have calculated it but no tested it. The price of the filter is rocketing ...
So I would say the best balance between performance / cost for stacking SolarSpectrum or DayStar etalons is with a 1.5A in a TEC.
If we go back to the Lunt / Coronado BF. Adding another 5 to 8 A BF would not change much the selectivity. Having or not a collimated / telecentric beam would not make a big change.
DSobserver
Been thanked: 19 times
Post by DSobserver »
I recently stack a coronado bf15 with a Lunt bf400:
Picture was very very dark
george9
Has thanked: 175 times
Been thanked: 429 times
Post by george9 »
I put my Lunt 2A prominence filter (from an old Prom 15T blocking filter) in series with my Quark and with my Lunt LS80 SS. It gets darker for sure. It seems a little higher contrast, but hard to tell because darker can fool you and look like more contrast. In fact, I A-B tested the 2A versus an ND filter, and the effect was similar. So I have the 2A mounted in a standard 1.25" cell, but I never use it.
On the other hand, putting my Lunt DSII unit in series with either my Lunt LS80 SS or my Quark produces a great view, not as dim as the 2A and clearly higher contrast.
George
