Hi Everyone.
I've posted a teaser collage of the Sun in four wavelengths in the main forum.
viewtopic.php?f=4&t=26584&p=239629#p239629
I thought I would add some more images here and start with H alpha.
The first three images are, in order, full disk H alpha spectroheliograms taken at line centre, line centre plus 0.74 Angstroms and a Dopplergram (+/- 34 km/s ).
For this imaging session, I wanted to try to increase the image scale and zoom in on the solar surface a little so I attached a Celestron 3x barlow to the Celestron NexStar 4 telescope which comprises the front end of the spectroheliograph. I didn't have a lot of optimism for this arrangement because I thought that seeing effects would be terribly bad at this expanded image scale. To my pleasant surprise, the results aren't too bad! Only a portion of the surface is imaged as a strip produced by the Sun drifting across the FOV. Here are the results, once again presented in the order line centre, line centre plus 0.74 Angstroms and a Dopplergram (+/- 34 km/s ).
Open these in a separate window for full size.
Comments and questions welcome.
Regards.
Peter
By the way, here’s the most recent version of the spectroheliograph:
14May2019 Spectroheliograms: H alpha
- Has thanked: 20779 times
- Been thanked: 10462 times
Re: 14May2019 Spectroheliograms: H alpha
These are great images Peter! I'm assuming the C4 is not front filtered at all - do you have no thermal issues with it?
- p_zetner
- Has thanked: 166 times
- Been thanked: 719 times
Hi Mark.
So far, I haven’t used any front filtering on the C4 but I’m thinking about it. In the previous incarnation of this SHG, I used a Rubinar 100mm f/10 which had some cemented field correcting lenses at the back end. I used a 100mm x 100mm Schneider IR-UV cut filter to try and reduce the thermal load on those lenses. I plan to add the Schneider filter to the C4 in the present arrangement. The SHG is very prone to seeing and thermal effects so it’s hard to tell if front filtering is necessary or beneficial but it’s probably a good idea to protect the optics.
Peter
Peter
- Has thanked: 17970 times
- Been thanked: 8905 times
These are terrific images Peter how did you produce the dopplergram?
- p_zetner
Hi Alexandra.
Thanks for the kind comment. I've attached a picture which gives a brief idea of how the dopplergram is constructed and what it shows. The explanation is a bit sparse but, hopefully, the idea comes through. Unlike a regular image in which the grayscale variations are due to the brightness variations of solar features, the dopplergram grayscale variations are proportional to line of sight velocities of the features, regardless of their intensities.
The montage below shows the (cropped) dopplergram (+/- 34 km/s) posted above after it has been colourized and superimposed on a spectroheliogram of the continuum at 656 nm and also superimposed on an H alpha spectroheliogram. In the colourized dopplergram, blue shows approaching gas and orange represents receding gas (infalling gas). The continuum spectroheliogram is shown in (a) and the dopplergram is superimposed in (c). The H alpha spectroheliogram is shown in (b) and the superimposed dopplergram is shown in (d). An interesting feature is the bright orange visible at the exterior boundary of the spot penumbra in (c). Quiescence over the penumbra itself and relatively fast flows at the exterior boundary seem to be the norm. (Leighton, Robert B., Noyes, Robert W. and Simon, George W. (1962) “Velocity Fields in the Solar Atmosphere, I. Preliminary Report” Ap.J., v135, p47. http://adsabs.harvard.edu/abs/1962ApJ...135..474L)
All the best.
Peter
All the best.
Peter
Wow! And I thought that my image train was long....
Thanks for the explanation and images. Be gentle to your heart, take care!
- p_zetner
Thanks for your comment and kind wishes, Bart!
The optics train is long but pretty sturdy. One thing about this type of spectroheliograph is that, generally, it doesn’t need to track. It remains stationary as the Sun “sweeps past”. I think, because of that, there’s more tolerance of flexure and other mechanical issues. The SHG stays well aligned, though, for many observing sessions and that’s with me hauling it out of the basement each time! I’ve actually improved the stability of the mounting somewhat since this photo was taken.
Peter
Peter
- Has thanked: 8543 times
- Been thanked: 8280 times
Excellent work, Peter. Is there any specific reason for selecting +/- 34km/s?
Keep well.
Keep well.
Hi Peter!
the more of your images I see, the more I feel I should start to build my own SHG! Extremely interesting project, thanks for showing!
Frank
Frank
