PST modification - idiots guide
langleif2
Re: PST modification - idiots guide
Post by langleif2 » Wed Oct 09, 2019 2:57 pm
As mentioned, you don't need the helical focuser. Especially if you want to remote control the focuser. You just need a back adapter or extension tube at the length of 14cm as seen on this picture:
Eventually you can take a look at my thread: "Is a C8 and a PST mod really useable". There you can also see a picture of my mod. I just took a SCT to 2" adapter and a 2" Skywatcher T2 visual back and added a T2 spacer and finally a T2 to 1.25" adapter. I took what was left of my spare parts. You can ask: Will a SCT to 2" adapter fit the etalon back? Yes, it's not exactly the same tpi but it fits nicely.
You don't need your 3x telecentric. If you want to you must remove the lenses in your etalon. But this will bring out your focal length where the magnification will be too much for the seeing and it will further open up the etalon bandpass. Not the way to go with an airspaced etalon. You can do it none the less but you will most likely need a suitable reducer.
If with your C11 the magnification is not enough with the PST mod natively, you can use a Barlow between the BF and the camera.
Has thanked: 1615 times
Been thanked: 633 times
Post by marktownley » Wed Oct 09, 2019 8:05 pm
Montana wrote:
Wed Oct 09, 2019 9:30 am
So my current plan is:
Order =
1. Baader 35nm Halpha
2. PST front adapter
3. PST etalon
4. PST back adapter (unknown length)
5. Extension tubes (5cm)
6. Blocking filter (5cm)
7. Helical focuser (5.5cm - 9.5cm)
8. 2” to 1.25” reducer
9. Camera
bring back focus to 20cm behind PST etalon assembly to camera chip
Does anyone know how long the PST back adapter is? also how does it slot on to an extension tube? Also what happens when I add a barlow or my 3x telecentric? do I have to take spacers out?
That should work. The PST back adaptor is just a 2" female holder, so the extension tube just slots in, the same as an eyepiece would. Once you've got that magic 200mm set it just stays set as it is. A barlow would go between it and the camera, your 2x or probably 2.5x pm would be a good combination.
Rusted
Has thanked: 762 times
Been thanked: 211 times
Post by Rusted » Fri Oct 11, 2019 4:46 am
I have some recent direct experience with helical focusers. Sorry, Frank, but my short TS was both hopeless and dangerous.
Mine soon developed a lot of slack. Moreover it is only held together with a long riveted pin which is heavily leveraged by the design.
Once the riveting breaks loose, which it will eventually given the poor design, the focuser literally falls apart.
You may have an expensive blocking diagonal, a binoviewer and some costly eyepieces dangling from that floppy little focuser!
I recently replaced my push-pull focusing using a series of extenders, with an Omegon 2" helical focuser.
This has worked very well and had enough travel to allow a Barlow to be used, or removed from the camera nose, without dismantling.
https://1.bp.blogspot.com/-U_hfUJVZfOI/ ... %2Brsz.JPG
On the subject of D-ERF safety: The focused beam from my 90mm, internal, Baader D-ERF in my 6" f/8 is hot! You would not want to place your hand in that red beam! The PST etalon seems to tame the heat but it makes you wonder how much heat it can tolerate. I often track the sun for hours. Capturing videos and processing them continuously throughout the day.
Has thanked: 1530 times
Been thanked: 521 times
Post by Montana » Fri Oct 11, 2019 9:48 am
Thanks guys for the OK, I will start ordering my list now. Hopefully pick everything up at the IAS show in November. Is anyone going?
Post by Montana » Mon Jan 13, 2020 7:55 pm
Hi guys, I have finally put everything together but not in the order I expected. Unfortunately the micro focuser I bought only has a screw in top so nothing fits in it apart from my 2" -1.25" adaptor. Are you allowed to put the blocking filter directly behind the etalon? I can obtain 20cm in length in this combination only.
ImagePST Mod by Alexandra Hart, on Flickr
Post by bart1805 » Mon Jan 13, 2020 9:05 pm
Yes Alexandra, that is no problem. A bit further back could be nice to see more of the sun (when the BF is small), but for HR imaging it is fine.
Post by marktownley » Mon Jan 13, 2020 11:16 pm
Looks good, it will work.
Has thanked: 582 times
Been thanked: 481 times
Post by Carbon60 » Tue Jan 14, 2020 6:43 am
Looking good, Alexandra.
Lunt LS60THa B1200 PTFT
DMK41, Basler acA1920-155
NEQ6 Pro-mount
AndiesHandyHandies
Has thanked: 164 times
Been thanked: 88 times
Post by AndiesHandyHandies » Tue Jan 14, 2020 8:50 am
It will vignette the image badly moving it right behind the etalon.
If you move it put it before the CCD.
I have done a full PST Mod and I am thinking of taking the blocker I do not use out of the abandoned PST and placing it in front of a small CCD camera for prominences set up.
Andrew
Post by marktownley » Wed Jan 15, 2020 6:10 am
What's the clear aperture on the Solarscope blocker Alexandra?
Post by Montana » Wed Jan 15, 2020 7:54 am
I don't know Mark, according to the chart ??? https://solarscope.co.uk/filter-systems/ :lol:
I'll have to measure at home tonight :)
Post by Montana » Wed Jan 15, 2020 10:03 pm
OK Mark, it is 35mm
Post by marktownley » Thu Jan 16, 2020 5:44 am
You wont have any vignetting issues with the solarscope blocker, it's bigger than the 20mm aperture of the etalon.
AndiesHandyHandies
Post by AndiesHandyHandies » Fri Jan 17, 2020 9:34 am
Ah. Thanks Mark.
