PST modification - idiots guide
Has thanked: 17672 times
Been thanked: 8791 times
Hello,
I have never been on this part of the forum before and it scares me to death.
Having got nowhere with Solarscope I need to make a Halpha etalon fit on the back of my C11 and I have no other option but to make one myself as I can't afford a Solar Spectrum. I have read Ken's guide to a PST mod but to be honest after the first few pages I glazed over, it is too technical for me to understand.
Is there a straight shopping list anywhere with 'you need to by these items xyz from this place' then put x here, y here and z here and plug it it in?
It needs to be really simple, no technical stuff!
or can I buy all the parts and pay someone to assemble it (does anyone sell them ready done)?
Obviously my first purchase needs to be a PST as I don't want to break mine up as I use it so often as a PST. At least I understand that bit :lol:
Apologies for being dumb.
Kind regards
MalVeauX
Has thanked: 1171 times
Been thanked: 1360 times
Re: PST modification - idiots guide
Post by MalVeauX »
Hi Alexandra,
The hard part is the D-ERF, which you have covered!
You will need these two adapters from AOK swiss (both the front & rear adapter).
http://www.aokswiss.ch/ayo/pst.html
You will need a blocking filter, such as a 10mm or 15mm Coronado blocking filter, you can get that commercially or used. Alternatively, you can use the PST's blocking filter but it requires some work and other adapters, and it's only 5mm so its limiting on larger sensors, but it is an option.
https://optcorp.com/products/coronado-b ... ing-filter
You will need a simple 2" extension of about 80~140mm in total (you can stack these) and these are commercially made as typical 2" extensions in 35mm, 50mm and 80mm lengths commonly. The focus point needs to be 200mm after the rear collimating lens in the PST etalon's housing and the diagonal of your blocking filter will absorb some of that. So it's tyipcal to have 140mm of extension after the rear PST adapter then the blocking filter, and after that is your camera and stuff. You can also get extensions that incorporate non-rotating helical focusers to give yourself fine focus in the imaging train.
Here's examples of 2" extensions commercially, they're common:
https://agenaastro.com/blue-fireball-2- ... nsion.html
Example of 2" extension with 1.25" helical focuser:
https://www.amazon.com/gp/product/B07HR ... UTF8&psc=1
Since you're using an SCT it's a lot simpler and you need less stuff.
The front PST adapter will have M48 threading to allow for standard filters to thread on. This is where you thread on a UV/IR block filter, or a Red CCD imaging filter, or a Baader 35nm HA filter to eliminate the rest of the heat (knowing your DERF passes 393 & 430 so there's still some heat coming through that is not needed/wanted since this is HA with the PST). I would suggest the Baader 35nm HA filter first. After that the Baader Red Imaging CCD-IR block filter.
You insert this into your SCT visual back.
Now, harvesting the PST etalon... that's another story. I have done all of this recently, so I can share via my threads:
Here I harvest a PST:
viewtopic.php?f=9&t=25420
Here I make a PST module that works in SCT, refractor, etc:
viewtopic.php?f=9&t=26560&start=25#p239784
I still ask for help doing this all the time because I'm not the expert, but hopefully this gets you started!
Here's my current PST module in my C8 Edge with the D-ERF:
From left to right:
2" Visual back -> Baader Red CCD IR blocking Imaging Filter (ERF #2) -> AOK Swiss Front PST Adapter -> PST Etalon -> AOK Swiss Rear PST Adapter -> 2" adapter with 1.25" helical focuser -> Coronado 10mm Blocking Filter -> ASI290MM camera
This allows me to focus the primary mirror with the SCT's focuser with the collimating lens in the appropriate spot to be at F10. Then I fine focus with the helical focuser near the camera.
Has thanked: 20442 times
Been thanked: 10247 times
Hi Alexandra,
You just need the 2 AOK adaptors, spacers like Marty says, you can use your blocker from the solarscope and all you have to do is unscrew the etalon from your PST. The black box screws off, just need to unscrew the gold tube. The rest of it is just screwing things together. Once you've done it you won't believe how tricky you thought it was, but in reality is not!
OK, many thanks guys but I am confused already, where do the spacers come into all of this? and what is a helical focuser?
Which 2" UV/IR blocking filter do I buy or do I buy all 3 mentioned?
Yes I do have a 2" blocking filter already from the Solarscope.
MalVeauX
Post by MalVeauX »
Heya,
The helical focuser is not needed, I just included it because I recently put one inline with a PST mod to add fine focus to the camera inexpensively and simply which also allows for less precision on the collimating lens placement in various scope designs. So for now, maybe ignore this part. It's not needed. Just a nice extra to know about.
So the PST etalon itself has two collimating lenses in the chamber, the front and rear lenses. See my threads above, there are pictures of them and everything. They are F10 each and require -200mm in focus placement on the front, and +200mm out focus on the back. So on your SCT, which is F10, you will simply insert the PST etalon with the two AOK swiss adapters and its stock collimating lenses still in place into your 2" visual back on your SCT, nothing else needed on that scope side of the etalon. Behind it though, you need that +200mm out focus behind it, as that's where the new focus point is. So you need spacers to go from the rear collimating lens in the PST chamber, 200mm out and that's where focus will be. Subtract anything that is in the imaging pathway from that 200mm, so your blocking filter or anything else you might use there. That's where the spacers come in. As it will likely be less than 200mm since you will have a blocking filter in there, so it's common to use shorter spacers in various combinations to achieve your goal based on what you use. Instead of long spacers, for example, I incorporated a helical focuser into this and my blocking filter diagonal to make up that space instead of just spacers. You can just use a spacer and your blocking filter (it just needs to add up in total length to about 200mm to the focus point to your camera).
You don't need all the above UV/IR/filters. Just one to complete the thermal blocking. The ideal one is the Baader 35nm HA 2" filter. It will thread onto your PST front adapter nose and block all unwanted heat other than 656 passing through.
Since you already have a blocking filter, you only need the PST AOK swiss adapters and the PST etalon of course and the spacers needed to get your camera, after the blocking filter, 200mm away from the rear of the PST collimating lens.
Here's a quick illustration to show what I mean about spacing 200mm behind the PST etalon's rear lens to the camera and whatever you use between there needs to add up to around 200mm (so spacers, blocking filter, anything else you put there). I happen to put a helical focuser in line because it adds space and gives me fine focus on top of that.
Thanks Marty, I need to go and look what I have :)
MalVeauX
Post by MalVeauX »
Montana wrote: Tue Sep 24, 2019 3:42 pm Thanks Marty, I need to go and look what I have :)
Really all you truly need are the PST AOK swiss adapters (front & rear) and the PST etalon itself. That's the heart & soul of it. You can go wherever you want from there with all kinds of stuff. A basic PST mod is just the AOK swiss adapters and a blocking filter with enough space between the focus point and the PST collimating rear lens to equal around 200mm. Using an SCT at F10 just makes it easier since you don't have to worry about the front train of the setup. Just thread a Baader HA 35nm 2" filter to the front of the PST front adapter and you'll be set, no heat coming out of that system with your D-ERF, very nice.
george9
Has thanked: 175 times
Been thanked: 426 times
Post by george9 »
Just curious, with an ERF in front of the C11, why add another HA filter in the back? Assuming the ERF is going to cover UV and IR and most of the visible (simple red glass will not). Is the PST etalon particularly sensitive? By the time you get to the blocker, the etalon comb filter gets rid of most of the energy. Seems like one more thing to create reflections.
Does it cover frequencies missed by the the blocker, etalon, and ERF? Is it being added for eye safety or filter safety?
Something like a SolarSpectrum has it's own ERF in front, so no need in that case. [Edit: I mean no need for a SECOND ERF in that case.]
George
Has thanked: 173 times
Been thanked: 615 times
Post by Merlin66 »
George,
Your point is well made!
The suggested Baader 35nm is exactly the same spec as the Baader D-ERF.
Belt and braces??
Alexandra,
I find the focuser almost mandatory. Once the etalon is positioned at the majic -200 mm you don’t want to move it. A helical focuser is a simple idea to allow you to focus different eyepieces and or cameras without additional spacers.
Executive Summary
Remove PST etalon assembly.
Add AOK 2” nosepiece to the front
Add AOK rear adaptor
Stack spacers, helical focuser, BF diagonal etc to bring back focus to 200mm behind PST etalon assembly.
Position the nosepiece in the scope to achieve the -200 mm at the PST etalon assembly.
ERF up front or sub diameter ERF should be fitted prior to etalon assembly.
HTH
Post by Merlin66 »
Which ERF did you use?
OK, I am convinced by the Baader 35nm H-alpha filter :)
Confused again. Is the 20cm behind the etalon a fixed physical distance or a focus distance?
On my C11 the focuser is to the side so when you focus you don't move the bit attached to the scope in and out, so why would a helical focuser help?
Post by Merlin66 »
Alexandra,
The 200mm is a fixed physical distance due to the rear lens in the etalon assembly.
If you use the scope focuser you’re effectively changing the -200mm spacing required for the front lens of the assembly. In effect the position of the scope focus is moved relative to the front lens.
The helical focuser allows you to compensate for the camera etc within the fixed 200 mm back focus
george9
Post by george9 »
Put another way, the helical focuser can help in two ways.
1. Because you are unlikely to find spacers of exactly the right length, the helical focuser lets you set the camera exactly 200mm back behind the etalon. Then use the SCT focuser to bring it into focus. How do you get exactly 200mm? If you can actually measure it, then great. But another way is to remove everything behind the etalon, but a screen (possibly translucent) 200mm behind the etalon, and adjust the SCT focuser to sharp focus. Then put the spacers and helical focuser and camera back on, and then adjust the HELICAL focuser (and spacers if needed) until it is sharp. That should be at 200mm.
2. The SCT focuser is not that great, so once you get everything to the best focus you can get with the SCT focuser, use the helical focuser to tweak it. Yes that will move you slightly off 200mm, but if you only go a mm, it won't hurt.
George
Thanks guys, it is all murky water at the moment but at least it isn't mud :) it is clearing slowly.
Have you got a 2" diagonal Alexandra? Also, is the solar spectrum blocker 2" or 1.25"?
I do have a 2" diagonal but I never like using it. My Solarscope blocker is 2"
With the AOK adaptor, an 80mm and 60mm extension tube, the 2" blocker and a 2" to 1.25" step down, along with the optical length of the camera you will be pretty much in the 200mm ballpark the chip needs to be from the etalon.
Just trying to source and cost things at the moment. Is this a good Helical focuser?
https://www.365astronomy.com/2-Non-rota ... Scale.html
Are these good?
https://www.harrisontelescopes.co.uk/ac ... ube-2.html
1 of them and 2 of them would equal the 14cm Mark suggested (I think). Thinking about it I think I only need one of each.
I need to measure the size of my blocking filter I think.
LTHB
Been thanked: 581 times
Post by LTHB »
I have tried several helical focusers, most of them were more or less wobbly, so this is the point I would pay attention to, but I have no experience with the focuser you linked to.
The best I tried out is this one:
https://www.teleskop-express.de/shop/pr ... ierer.html
Frank
bart1805
Been thanked: 1 time
Post by bart1805 »
Hi Alexandra,
It all depends on the light path of the blocking filter you are going to use. With a Lunt diagonal, the distance between the back of the rubber ring of the etalon to the front edge of the diagonal is about 11 cm.
If I look at your earlier pictures made with your C11, it seems that focussing is not a big issue. If that is the case than you can use the gold tube of the PST to check if your distance from the etalon to the camera is right. Aim at 20 cm. Screw the gold tube back on the etalon. Focus with the helical focuser. When focussed you have found the right distance. Attach the mod (without the gold tube off course....) to your C11. Focus your C11 an there it is. No need to use the helical focusser for fine focussing.
CS! Bart.
Post by Merlin66 »
My previous message seems to have got lost in space....
You don't need a 2" focuser....
I went for the Borg 1.25" Helical focuser and use it on all the Spectra-L200 spectrographs as well as the SHG.
The focus on the donor scope should be fixed, and any re-focus requirements due to cameras, eyepieces etc, should be done after the etalon.
Montana wrote: Mon Oct 07, 2019 12:00 pm Just trying to source and cost things at the moment. Is this a good Helical focuser?
Are these good?
I have one of those helicals, they're ok. The distance you need from the back lens of the etalon to the chip is 200mm.
Have a look on astroboot, you can often get adaptors and spacers considerably cheaper on there.
So my current plan is:
Order =
1. Baader 35nm Halpha
2. PST front adapter
3. PST etalon
4. PST back adapter (unknown length)
5. Extension tubes (5cm)
6. Blocking filter (5cm)
7. Helical focuser (5.5cm - 9.5cm)
8. 2” to 1.25” reducer
9. Camera
bring back focus to 20cm behind PST etalon assembly to camera chip
Does anyone know how long the PST back adapter is? also how does it slot on to an extension tube? Also what happens when I add a barlow or my 3x telecentric? do I have to take spacers out?
Montana wrote: Wed Oct 09, 2019 9:30 am So my current plan is:
Order =
3. PST etalon
9. Camera
That should work. The PST back adaptor is just a 2" female holder, so the extension tube just slots in, the same as an eyepiece would. Once you've got that magic 200mm set it just stays set as it is. A barlow would go between it and the camera, your 2x or probably 2.5x pm would be a good combination.
Rusted
Has thanked: 8016 times
Been thanked: 1938 times
Post by Rusted »
I have some recent direct experience with helical focusers. Sorry, Frank, but my short TS was both hopeless and dangerous.
Mine soon developed a lot of slack. Moreover it is only held together with a long riveted pin which is heavily leveraged by the design.
Once the riveting breaks loose, which it will eventually given the poor design, the focuser literally falls apart.
You may have an expensive blocking diagonal, a binoviewer and some costly eyepieces dangling from that floppy little focuser!
I recently replaced my push-pull focusing using a series of extenders, with an Omegon 2" helical focuser.
This has worked very well and had enough travel to allow a Barlow to be used, or removed from the camera nose, without dismantling.
https://1.bp.blogspot.com/-U_hfUJVZfOI/ ... %2Brsz.JPG
On the subject of D-ERF safety: The focused beam from my 90mm, internal, Baader D-ERF in my 6" f/8 is hot! You would not want to place your hand in that red beam! The PST etalon seems to tame the heat but it makes you wonder how much heat it can tolerate. I often track the sun for hours. Capturing videos and processing them continuously throughout the day.
Thanks guys for the OK, I will start ordering my list now. Hopefully pick everything up at the IAS show in November. Is anyone going?
Hi guys, I have finally put everything together but not in the order I expected. Unfortunately the micro focuser I bought only has a screw in top so nothing fits in it apart from my 2" -1.25" adaptor. Are you allowed to put the blocking filter directly behind the etalon? I can obtain 20cm in length in this combination only.
ImagePST Mod by Alexandra Hart, on Flickr
bart1805
Post by bart1805 »
Yes Alexandra, that is no problem. A bit further back could be nice to see more of the sun (when the BF is small), but for HR imaging it is fine.
Looks good, it will work.
Has thanked: 8418 times
Been thanked: 8163 times
Post by Carbon60 »
Looking good, Alexandra.
AndiesHandyHandies
Has thanked: 3295 times
Been thanked: 1887 times
Post by AndiesHandyHandies »
It will vignette the image badly moving it right behind the etalon.
If you move it put it before the CCD.
I have done a full PST Mod and I am thinking of taking the blocker I do not use out of the abandoned PST and placing it in front of a small CCD camera for prominences set up.
Andrew
What's the clear aperture on the Solarscope blocker Alexandra?
I don't know Mark, according to the chart ??? https://solarscope.co.uk/filter-systems/ :lol:
I'll have to measure at home tonight :)
OK Mark, it is 35mm
AndiesHandyHandies wrote: Tue Jan 14, 2020 8:50 am It will vignette the image badly moving it right behind the etalon.
You wont have any vignetting issues with the solarscope blocker, it's bigger than the 20mm aperture of the etalon.
AndiesHandyHandies
Ah. Thanks Mark.
