Animation test
Has thanked: 39 times
Been thanked: 27 times
Animation test
Post by ffellah » Sat Oct 05, 2019 7:54 pm
This is my first animation test done with Alexandra's help. Only 31 frames over a little more than half hour this morning. Her solar nutcase tutorial is great and she is always so helpful and kind ! I know it is very rough but I will get better with practice. It is a lot of work, specially the first time, but the end result is a lot of fun !
Clear skies to all !
Starry Jack
Has thanked: 10 times
Been thanked: 30 times
Re: Animation test
Post by Starry Jack » Sat Oct 05, 2019 8:00 pm
It’s WONDERFUL
Aeries D-ERF
ZWO174 (IMX249 chip 5um)
Martin_S
Has thanked: 18 times
Been thanked: 86 times
Re: Animation test
Post by Martin_S » Sat Oct 05, 2019 8:37 pm
Well done Franco.
Martin
H - alpha setup
White Light setup
Skywatcher ED72 , Homemade solar wedge, IR cut filter, ND3.0 filter, #58 green filter
Mounts
Darkside setup
Skywatcher ED72 , GSO RC6
MAURITS
Been thanked: 14 times
Re: Animation test
Post by MAURITS » Sat Oct 05, 2019 9:03 pm
Lovely animation Franco.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
Re: Animation test
Post by ffellah » Sat Oct 05, 2019 9:56 pm
Thank you Jack, Martin and Maurits. At least now I understand the process, the software and the steps involved...
Has thanked: 635 times
Been thanked: 217 times
Re: Animation test
Post by Montana » Mon Oct 07, 2019 9:03 am
What a great start Franco :hamster: :bow
I would try a Barlow next time to get a bit closer in. Are you using Photoshop? if so remember to use the 'record actions' function to automate some processing and save time. Also when in the animation view part you can crop your image until you see some of the black boundaries disappear in the final animation.
Re: Animation test
Post by ffellah » Tue Oct 08, 2019 9:47 am
Thank you for the tips, Alexandra
Franco :bow2
Has thanked: 803 times
Been thanked: 309 times
Re: Animation test
Post by marktownley » Tue Oct 08, 2019 7:50 pm
Good result Franco! I suspect i've gone past the season for my sm90 now, back down to 50mm aperture for me with lower sun...
Re: Animation test
Post by ffellah » Wed Oct 09, 2019 11:07 pm
Thank you, Mark. I hope I will still use it this season, maybe for another animation, if the opportunity presents.
