New Plage, Proms & Cells | Oct 29th 2019
Has thanked: 19 times
Been thanked: 25 times
Post by MalVeauX » Tue Oct 29, 2019 7:40 pm
Woke up to an ok sky, clouds, but had a chance. Got some data later in the afternoon, so seeing was poor, but managed. The new plage is interesting and there are some proms in the quadrants on the limbs. Took at look at the plage in two scales and both from the chromosphere & photosphere perspective.
Colored:
B&W:
Equipment:
C8 Edge + Aires D-ERF + Baader Red CCD-IR Block Filter
120mm F10 Frac
PST Module
ASI290MM
Has thanked: 185 times
Been thanked: 178 times
Re: New Plage, Proms & Cells | Oct 29th 2019
Post by Carbon60 » Wed Oct 30, 2019 6:48 am
A great set of images, Marty. Nice to see a little activity stirring up, there. Looks good in WL too.
Lunt LS60THa B1200 PTFT
DMK41, Basler acA1920-155
NEQ6 Pro-mount
banjo
Has thanked: 7 times
Been thanked: 68 times
Post by banjo » Wed Oct 30, 2019 7:32 am
Superb Marty. :bow :bow :bow :bow
MAURITS
Been thanked: 14 times
Post by MAURITS » Wed Oct 30, 2019 8:02 am
Excellent images Marty.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
Has thanked: 726 times
Been thanked: 278 times
Post by marktownley » Wed Oct 30, 2019 8:54 am
These are excellent images Marty!
Has thanked: 39 times
Been thanked: 26 times
Post by ffellah » Wed Oct 30, 2019 9:54 am
Nicely done, Marty. Excellent close up of the active region.
Has thanked: 591 times
Been thanked: 199 times
Post by Montana » Wed Oct 30, 2019 11:54 am
Super images but in the WL I don't think I can see any pores so that is a bit disappointing but then again I don't think we can hope for much these days out of cycle 24 :) Still a beautiful swirl in Halpha though :hamster:
:bow :bow
MAURITS
Post by MAURITS » Wed Oct 30, 2019 9:16 pm
Marty, is the first image in WL done with a wedge or with film filter?
Maurits
Has thanked: 3 times
Been thanked: 59 times
Post by MapleRidge » Wed Oct 30, 2019 11:34 pm
Excellent images Marty :bow
That bit of activity looked promising, but has never grown into anything that NOAA assigned a number to!
Post by MalVeauX » Thu Oct 31, 2019 2:25 pm
Thanks all :bow
I don't use film nor wedges for imaging, they lower transmission too much.
That first image was done with my C8 Edge and my full aperture Aires D-ERF followed by a Baader Red CCD-IR blocked filter (2nd erf). The transmission is so high that I have to then use a Baader 10 stop ND filter. I sometimes then use a Baader 610nm filter after that, but it's not needed. Transmission is still so high that this only gives me a little room to work with since the shortest exposure is 0.032ms and this one was at 0.281ms with no gain.
When I do it with my refractor, I only use a Baader Red CCD-IR block filter as the primary ERF deep in the light cone, or the Blue version of the same filter if I'm doing 393nm or 430nm. And then follow it with a narrowband filter with an appropriate UV/IR block filter to complete the blocking but maintain high transmission. And I often have to use a 10 stop ND filter here too to lower transmission enough to not saturate at the shortest exposure.
MAURITS
Post by MAURITS » Thu Oct 31, 2019 5:01 pm
Thanks Marty for the clear explanation.
Maurits
Astrophil
Been thanked: 60 times
Post by Astrophil » Sun Nov 03, 2019 3:54 am
They all turned out very well, Marty. Beautiful hi-res shots!
Phil
