Convert my William Optics ZS80IIED
p1taylor
Has thanked: 1 time
Been thanked: 219 times
Post by p1taylor »
Hi, Can I convert my William Optics ZS80IIED to a H-alpha solar scope with blocking filter straight through B1200S tube and a internal pressure tuner as it will be out in my observatory then I can control it with a PCUSB Pressure Tuner, scope as a focus motor on.
peter
Has thanked: 20738 times
Been thanked: 10436 times
Re: Convert my William Optics ZS80IIED
Hi Peter, yes in theory you can. What donor scope are you using for the Ha side of things?
p1taylor
Has thanked: 1 time
Post by p1taylor »
Hi Mark, I will try to get them all from Lunt new or is there a beater supplier.
peter
What's your idea Peter? Front mounted etalon?
p1taylor
Has thanked: 1 time
Post by p1taylor »
My idea was to do it as Lunt do the pressure tuner after focuser as the Lunt LS60THa/B1200 is.
peter
You'll be cutting the tube on the WO then...
p1taylor
Has thanked: 1 time
Post by p1taylor »
Hi Mark, Thanks for your help but if it means cutting WO I will got a new Lunt scope.
peter
Which one are you thinking of Peter? FLO have a Lunt60 reduced at the moment. https://www.firstlightoptics.com/offers ... 95903.html
p1taylor
Has thanked: 1 time
Post by p1taylor »
Yes that is the one I was thinking of.
peter
That's a good price, if you can get it while you can save some £££.
