Hi first post here!
Have a chance to buy a PST double stack (used) for an extremely favourable price. Have seen the conversions to 80mm and 100mm done with the single stack, but can the double stack be used in the conversions also?
TIA
Gary
PST conversion?
- Been thanked: 10489 times
Re: PST conversion?
Hi Gary, welcome to the forum. You can't realistically use a external double stack etalon in a PST mod.
Re: PST conversion?
No, they have a central obstruction that will be visible in a collimated beam.
- daslolo
- Has thanked: 4 times
- Been thanked: 3 times
Re: PST conversion?
I've seen that happen on my SCT when out of focus but it goes away when in focus (still don't know how).marktownley wrote: ↑Thu Feb 20, 2020 8:57 amNo, they have a central obstruction that will be visible in a collimated beam.
Can you explain?
I have :
beams entering the tube are parallel, go through the second etalon parallel which punches a hole in the middle with that obstruction, then telescope lens converges them to the correcting lens before the etalon, turn them parallel again through the etalon then back to converging after the second correcting lense, that hole is still there, same ratio to the image. So yeah that makes sense.
Why don't SCT not show the obstruction?
LX65 8" ACF
LX65 8" ACF
- Has thanked: 3317 times
- Been thanked: 1907 times
Re: PST conversion?
The black hole does not normally show.
For stars it inside the diffraction pattern.
I lent a F5 Newtonian to a friend and he noticed the dark hole in the middle in daylight and thought there was a fault.
Andrew
Andrew
- daslolo
Re: PST conversion?
Stars wavelength is shorter than the obstruction?
LX65 8" ACF
LX65 8" ACF
Re: PST conversion?
The obstruction blocks light in the middle of each diffraction pattern, which a lot of make up the image.
On night time objects like star fields it not noticible.
In the day you can see the field has a dark part in the centre due to the obstruction of the light in the centre.
Andrew.
Andrew.
Re: PST conversion?
I was thinking about this since, i'm wrong in saying the central obstruction will be visible in a collimated beam, it is visible in a telecentric beam. Think about the Coronado SMII scopes, their etalon has a central spacer in the etalon which sits in a collimated beam.marktownley wrote: ↑Thu Feb 20, 2020 8:57 amNo, they have a central obstruction that will be visible in a collimated beam.
Practically, can you double stack a PST etalon with a SM etalon? Realisitically no, the central spacer in a SMII etalon is ~12mm(? not measured it?), PST etalon is 20mm diameter so would eat a chunk off it. You could mount it offset so the central spacer is not in the light path, but then you're in the realms of custom made parts.
