The past few days saw an outbreak of beautiful aurora around the poles although there was no significant solar activity to be seen. What did occur was the interplanetary solar wind, which carries with it a magnetic filed, flipped south sporadically and this allowed the solar wind to penetrate deeper than usual into our magnetic shield, exciting oxygen and nitrogen in our upper atmosphere. The geomagnetic effects were easily detected on my magnetometer here in the UK, as shown below.
I've also summarised the geomagnetic activity over the past month since Dec 8th. Coupled with an uptick in cycle 25 activity, 2020 seems to be off to a good start.
Thanks for looking.
Geomagnetic Unrest Jan 2020
- Has thanked: 8418 times
- Been thanked: 8162 times
- Been thanked: 4340 times
Re: Geomagnetic Unrest Jan 2020
Hi Stuart...
Great review of the events and I've been following the reports on SpaceWeather where your observations have been posted as well.
Always great to see your data as so few have your type of setup to monitor this activity.
- Been thanked: 8791 times
Great data Stuart! I saw on Spaceweather about this flipping, glad you saw it too on your monitors we need some clear skies and some auroras to come south.
- Has thanked: 20438 times
- Been thanked: 10245 times
Excellent record again Stuart!
Many thanks Brian, Alexandra and Mark.
