Full Disc 15 January 2020
rsfoto
Has thanked: 2653 times
Been thanked: 1981 times
Post by rsfoto »
High and thin clouds infront of the Sun but enough light so I thought to give it a try it and below the result. Sorry for the bad quality :oops:
If yout ake a look at the SDO magnetogram image you can see in the northern hemisphere a cycle 24 and a cycle 25 spot. The most left one is cycle 25 :shock:
and below is how the Sun looked through the clouds.
Been thanked: 1459 times
Re: Full Disc 15 January 2020
Post by eroel »
Rainer:
Nice result in spite of conditions, at home I had about the same problem (thin high clouds).
Fuerte abrazo,
Has thanked: 1357 times
Been thanked: 746 times
Post by ffellah »
Hi Rainer: very nice results in spite of the thin clouds. Are you still using the Daystar filter? If you are, which one ?
Franco :bow
JochenM
Has thanked: 531 times
Been thanked: 874 times
Post by JochenM »
Good job managing to get that image (I think it's still good) in those type of conditions.
Has thanked: 4476 times
Been thanked: 1976 times
Excellent image, especially given those hazy skies, i'm hoping the weather allows me to get the solar scope out this weekend at some point.
Has thanked: 4058 times
Been thanked: 1658 times
Franco, somehow I don't think a full disc that superb came from a Daystar filter (sorry, am I allowed to say that?).
Rainer, another wonderful disc, you are very lucky to have that filter set :bow
rsfoto
Post by rsfoto »
ffellah wrote: Thu Jan 16, 2020 1:14 am Hi Rainer: very nice results in spite of the thin clouds. Are you still using the Daystar filter? If you are, which one ?
Franco :bow
Hi Franco,
Sorry no. Both DayStar filters I bought in April 2018 has gone back to DayStar as both were blind. Everytime I read the word DayStar I get angry :lol:
That purchase was a total failure and even worse the way DayStar handled the complain. Weeks and weeks with no answers ...
DayStar is dead for me for all times ...
I have now only a very double stacked Coronado SM 60 with BF 30 ...
Rainer
Post by ffellah »
Rainer: you are a magician ! You certainly are doing a magnificent job of full disks with the SM 60 double stacked. I wish I could do the same with my SM90 DS. The 90 is traditionally not easy to put in band due to the length of the scope: you need orangutan arms to tune the external etalon while you look into the eyepiece. Once it is band, though, the results are excellent.
rsfoto
Post by rsfoto »
ffellah wrote: Thu Jan 16, 2020 7:06 pm Rainer: you are a magician ! You certainly are doing a magnificent job of full disks with the SM 60 double stacked. I wish I could do the same with my SM90 DS. The 90 is traditionally not easy to put in band due to the length of the scope: you need orangutan arms to tune the external etalon while you look into the eyepiece. Once it is band, though, the results are excellent.
Hi Franco,
I am no magician. I have the advantage of being able to adjust very fine the etalons remotely while looking on my monitor. I made that 7 seven years ago.
Look here viewtopic.php?f=9&t=26907&p=243127&hili ... er#p243127
Below the drawings of the parts you need to machine. OK, then you need a 10mm stepper motor with high reduction gears, a bellow couples, a screw which changes the angle, and a stepper motor driver and a little piece of software to move the stepper motor step by step ...
Rainer
salvo lauricella
Has thanked: 56 times
Been thanked: 75 times
Post by salvo lauricella »
Excellent image!
Has thanked: 10 times
Been thanked: 868 times
Post by MapleRidge »
Hi Rainer...
You have certainly mastered the full disk mosaics with that scope. Superb image despite the cloud :bow
C9.25 Edge + Stellarvue 110, f7 or C14
Deep Sky Work - Canon 60D (Ha mod), SBIG STF8300/FW8, ONAG
Planetary Work - SBIG CFW10, ASI290MM/ASI462+ADC
8' Diameter Dome
MI250 Mount carrying:
Celestron CR-150 150mm, f8 OTA Modular Setup
Ha configuration: 2xDSII/B1800Ha/Daystar ERF as modded Ha Scope
WL & CaK configuration: Lunt WL Wedge or Modded B1800CaK Wedge
Lunt LS80PT/LS75FHa/B1200Ha
Daystar Quantum 0.45A SE, Quark Combo Chromosphere,
ASI1600MM, ASI174MM, ASI290MM, PGR Grasshopper Express
