Tuning or bandwidth?
Astrophil
Been thanked: 118 times
Post by Astrophil » Thu Jan 16, 2020 5:47 pm
We all strive to produce the best images from the equipment we have available to us. However, some images appear better than others. Putting resolution aside, my rudimentary knowledge of solar imaging leads me to the question of whether proper etalon tuning or system bandwidth is of primarily importance. Obviously both play an important role but how can it be determined which is primarily responsible for less than ideal images.
I am currently using a Lunt 80 pressure tuned etalon solar scope with an additional pressure tuned secondary. Placed between the etalons is a circular polarizer to minimize internal reflections. Instead of a blue filter before the blocking filter, I use a Lunt supplied filter that is more transparent, for imaging only. The advertised bandwidth is 0.5 angstroms and by double stacking the continuum leakage should be minimized.
My tuning ritual consists of the following. Beginning with the primary etalon, I adjust to obtain best contrast between filaments and the surface while minimizing the histogram. These usually coincide. At the same time the secondary is adjusted to match the primary by watching the histogram and brightness increase. This usually takes a few iterations before achieving what I think is optimal. This may or may not be the correct way to tune. Opinions welcome.
The Lunt 80 is a nice portable scope that delivers in my opinion a good image. I just wonder if or how they could be improved. Thanks for any suggestions.
Below are some images taken on the 15th of January.
Phil
rsfoto
Has thanked: 882 times
Been thanked: 660 times
Re: Tuning or bandwidth?
Post by rsfoto » Thu Jan 16, 2020 6:47 pm
Hi Phil,
Looking at your images and my limited knowledge i would say you are very close to both best parameters. Not being able to look by myself into that due to now having the scope present it is also difficult ot judge.
As you said with a few iterations one tries tog et closer to that and as I can not see how it changes it is difficult to say if there is a better point then the one you are presenting.
Comparing you images to mine they are very close up to 95 equal ...
This tuning and Bandwidth-ing is subjective too. One day it will be better and the next one worse due atmospheric conditions.
All in all they look very good and BTW I stopped colouring my discs as I had the impressión that with colour somehow they looked less sharp the in B&W ... OK, that is also subjective and is a matter of Taste ...
Rainer
rsfoto
Post by rsfoto » Thu Jan 16, 2020 7:02 pm
Hi Phil,
I hope you do not mind but I downloaded your B&W image and processed it a bit according to my taste.
You have some residuals there in the histogram which makes your image a bit opaque as well as you can stretch it on the white side a bit more. OK, I have to be careful as monitor settings do playt a big role how others appreciate the images. Also if one converted to colour sRGB or not ... In this respect I calibrate my monitors every two weeks.
Below full image retouched a bit by me according to my taste
and below half and half. Left your original, right the retouched image
rsfoto
Post by rsfoto » Thu Jan 16, 2020 7:24 pm
Hi Phil,
Look at the image below where I took your histogram and how I changed it. Red lines is your original image histogram and green is how I stretched it a bit.
Just as an idea how stretching the histogram can also influence what we see as sharpness = contrast.
Astrophil
Post by Astrophil » Thu Jan 16, 2020 8:10 pm
Thank you so much, Rainer. I like your results of reprocessing the image. Much better, even using the compressed jpeg.
I have not calibrated my monitors in a long time. That will be next on my to do list. I tend to agree that grey scale images show the beat detail. Someone once said that if the image is not the best, colorize it. If that doesn't help then invert it. If still not satisfactory, do both. I think in my case I must tend to make it dark and dull to mask inadequacies, subconsciously of course.
The multiple iterations is to insure that the primary etalon tuning is not overly influenced by the secondary etalon's initial setting. I agree that once both are set, no further tuning is necessary.
I appreciate your help and advice. It was your excellent images that prompted the concern over my scope's performance and imaging abilities. ;-)
Phil
Has thanked: 19 times
Been thanked: 89 times
Post by Valery » Fri Jan 17, 2020 4:39 am
In my opinion Phil's images are better balanced and they better represent what is seen on the sun.
They also consist more shades between the spiculaes (dark bushes on the disk).
Rainer's images looks too much contrasty - just like more wide etalons show in a telescope. The space between disk spiculaes are more washed out (too bright less details).
This is seen on my monitors on Dell Inspiron lap top with its native 17" and external 24" and the same seen on the screen of my MacBook Pro 13".
Usually, the narrower the bandwidth the more grayish the solar disk looks - more delicate shadows in between dark filaments and spiculae bushes and to the "surface" of the disk. And I need to change the contrast somewhat and to change the profile of the gamma curve to make these delicate shadows more visible.
Again, this is to my own taste and according to my understanding of the solar features nature and how do we see them in our telescopes.
CS,
rsfoto
Post by rsfoto » Fri Jan 17, 2020 3:53 pm
They also consist more shades between the spiculaes (darkes bushes on the disk).
This is on my monotors on Dell Inspiron lap top with its native 17" and external 24" monitors and the same on the screen of my MacBook Pro 13".
Again, this is to my own taste and according to my understanding of the solar features nature and how do we see them in out telescopes.
Hi Valery,
You are right ... Maybe I exaggerated a bit in order to show how processing can influence what we see.
As you say it resumes all to Taste ... Have a nice day.
Rainer
Astrophil
Post by Astrophil » Fri Jan 17, 2020 5:24 pm
Taste aside for a moment. In order to image bright plage, dark filaments, and to easily visualize filaproms, is a certain minimum bandwidth required or is it only camera settings or selective post processing?
My reference library is lacking and knowledge of this subject inadequate so any thoughts would be most welcome.
Phil
Has thanked: 151 times
Been thanked: 146 times
Post by MalVeauX » Fri Jan 17, 2020 5:49 pm
There's a bit more to the tuning, since it's not just an issue of being on-band, it's about the transmission profile. The same reason a 0.3A single etalon will not eliminate the photosphere leaking through showing the double limb. Mean while, two 1A filters can stack and shave off the skirt of the transmission profile removing the photosphere from leaking through rather well, at a cost of lower transmission of course. So tuning is very critical of course. Sometimes we're close to on-band, sometime's a little off-band, when we're on-band and the filaments are super dark and plages very bright, the high contrast is pleasing (looks sharp without sharpening, a function of contrast). If the two are not tuned together of course, then there's issues. Bandpass is not as critical. 1A, 0.7A, 0.5A, 0.3A, etc, whatever number you want, the single etalons leak photosphere light. The bandpass number is largely no that useful even. Something that is 0.7A and 0.5A really doesn't matter, the transmission skirt is what matters, and that's where double stacking comes in, not to just tighten bandpass, but to effectively suppress the out of band wavelengths that are leaking through on the sides of the transmission curve. I would take two 1A~0.7A filters over a single 0.3A filter for limb shots for this reason. The alternative is a very narrow blocking filter, instead of the 6A blocking filters, a 1A blocking filter would do it (but that's a unicorn).
Lovely discs!
Has thanked: 4 times
Been thanked: 29 times
Post by Merlin66 » Sun Jan 19, 2020 6:55 am
I am aware that there are 3A blocking/ sort filters being tested........
Has thanked: 1586 times
Been thanked: 628 times
Post by marktownley » Sun Jan 19, 2020 10:51 am
I think your images are excellent Phil, but I do know what you mean. When I double stack my Lunt 50mm etalon with my Quark, I don't get as much contrast as when I double stack the same Quark on my SM90ii.
I wonder whether the difference is not a matter of bandwidth or tuning, rather the finesse (reflectivity efficiency) of the etalon that causes the difference of contrast?
Astrophil
Post by Astrophil » Mon Jan 20, 2020 10:22 pm
I appreciate the great info. I'm still working on proper tuning of the two etalons to maximize contrast. Interesting to note the difference between your Lunt and Coronado double stacks Mark. Finesse or maybe blocking filter differences? I guess more study is needed.
I tried stacking the Lunt pressure tuned scope with a Quark today with dismal results. Perhaps the Lunt blocking filter is not optimized for the Quark. I did not think about switching to the Quark blocking filter instead. May next time.
Marty's comment about the transmission skirt seems valid when considering increased contrast of filaments. This would apply to the finesse of the etalon as well as the blocking filter, hence the difference in Mark's results.
So, if one was to build or buy a system that was optimized for filaprom imaging, where would they start?
One last question. When comparing images from a single stacked Lunt 80 to a double stacked, should there be a huge difference? I'm not seeing much in mine. Attached are two images taken on the 18th. One is single stacked and the other is double stacked.
Phil
Post by Valery » Tue Jan 21, 2020 4:37 pm
The only reason that SS and DS look identical is: blocking filter has shifted blue or red and transmits the energy from other peak of the etalon. You can try Coronado BF or may be use a BF heater.
The nature of the LS80THa PT + Quark fail is that LS80THa has a sweet spot with progressive CWL shift blue from the sweet's spot center to it's edge while Quark has nearly the same CWL accross the FOV if the Quark is of a good CWL uniformity.
Hope this helps
rsfoto
Post by rsfoto » Tue Jan 21, 2020 5:26 pm
Hi Phil,
I am not an expert in all those technical explanations but when comparing images I put them together in one image and compare.
Left side Double stack and right side Single stack.
What I see is that DS has more visible plague then SS :roll:
Astrophil
Post by Astrophil » Wed Jan 22, 2020 2:33 am
Thanks for the explanation, Valery. I won't waste time with the pressure tuning and Quark combo. I'll try heating the blocking filter but will have to think about getting a Coronado BF for a while. Lunt Solar might have some suggestions or remedies.
Rainer, I too noticed a slight improvement with the double stack. thanks for the comparison shots. Not sure that I can see a $1300 improvement though.
Phil
Post by marktownley » Thu Jan 23, 2020 6:30 am
You'll notice a huge difference with DS when the sun is busy Phil
MAURITS
Been thanked: 26 times
Post by MAURITS » Fri Jan 24, 2020 4:12 pm
Phil
Phil, these images are beautiful.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
Astrophil
Post by Astrophil » Fri Jan 24, 2020 5:30 pm
Mark, those are encouraging words and tuning should be easier when the activity picks up as well. The waiting is shear agony.
Maurits, thanks.
Phil
hopskipson
Has thanked: 5 times
Been thanked: 3 times
Post by hopskipson » Sat Jan 25, 2020 12:14 am
Nice images Phil! I definitely see a difference in contrast with the DS images, especially the filaments and plage.
