Prominences & Filaments | HA & CaK | Feb 9th 2020
Has thanked: 172 times
Been thanked: 155 times
Post by MalVeauX » Sun Feb 09, 2020 5:49 pm
Another clear day, but the seeing was poor for my area typically. Regardless it supported the image scale (0.5"/pixel) in both wavelengths with lucky imaging. Took a look at today's prominences, some faint ones, and some nice dark filaments. No real noteworthy surface features today otherwise. Earth scales provided for the prominences. Most of them are on the Eastern limb quadrants. Both chromospheres represented, the lower & upper via Ha & CaK.
Colored:
Earth Scales:
B&W:
Seeing Data (SSM):
Equipment:
120mm F10 Frac
Baader Red CCD-IR Block Filter (D-ERF) + PST Etalon + 10mm BF + ASI290MM
Baader Blue CCD-IR Block Filter (D-ERF) + Lunt CaK 1200 + ASI290MM
rsfoto
Has thanked: 1028 times
Been thanked: 741 times
Re: Prominences & Filaments | HA & CaK | Feb 9th 2020
Post by rsfoto » Sun Feb 09, 2020 6:28 pm
Hi Marty,
Good Close-Up images. Not much activity :(
MAURITS
Been thanked: 30 times
Post by MAURITS » Sun Feb 09, 2020 9:00 pm
Great work Marty.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
Been thanked: 611 times
Post by eroel » Mon Feb 10, 2020 3:53 am
Marty:
A very fruitful session.
JochenM
Has thanked: 155 times
Been thanked: 486 times
Post by JochenM » Mon Feb 10, 2020 4:28 am
Nice work again.
Small question if you don't mind. Where exactly did you place the Blue CCD filter? The Lunt CaK module doesn't have any the possibility (at least mine doesn't) to thread it on.
All my images at: https://flickr.com/photos/jochenmaes/
My photography site: http://jochenmaes.com/
Has thanked: 1765 times
Been thanked: 607 times
Post by Montana » Mon Feb 10, 2020 10:30 am
All of them are delicious today Marty :hamster: :bow
Martin_S
Has thanked: 47 times
Been thanked: 161 times
Post by Martin_S » Mon Feb 10, 2020 10:33 am
Great Images ,as always Marty . Thanks for sharing them.
Martin
H - alpha setup
White Light setup
Skywatcher ED72 ,ED100, Homemade solar wedge, IR cut filter, Solar Continuum filter.
Mounts
Skywatcher HEQ5 Pro Mount ..
Darkside setup
Skywatcher ED72 ,ED100, GSO RC6 ,Celestron Nexstar 6SE.
Post by MalVeauX » Mon Feb 10, 2020 11:22 am
I put a 35mm 2" extension in front of it, with the filter threaded on there. Inserted the Lunt filter into that.
I'm thinking of disassembling the Lunt filter though. I consider it imaging only, so I don't need any of its protection filters, whatever is in there, or at least the visually protective filters. Just enough to protect the filter itself but otherwise, I'd love to get rid of anything not needed, to help increase transmission. It's ok as it is, but it's a wonky filter to use since it's so large and so long with it's 2" barrel and whatever is in it.
JochenM
Post by JochenM » Mon Feb 10, 2020 12:35 pm
That makes sense, thanks (couldn't make it out on the picture).
I was also quite surprised at the size of the Lunt CaK module when it arrived (or well, the 2" tube part that goes into the focuser at least). However, I'm not sure what purpose the silver filter (I'm sure you know what I'm referring to) on the front of the tube serves exactly. If it's just an ERF, then it shouldn't be an issue to remove it and replace it with whatever you want to use for that purpose. But if it's coated in some way to serve other purposes, then it might be tricky.
Post by MalVeauX » Mon Feb 10, 2020 3:40 pm
I don't know for sure what all the glass is in the filter (Lunt CaK), but I'm pretty sure most of it is ERF and ITF for energy handling and visual safety. The CaK filter itself is just a single filter at 2.4A. But I don't know enough about whats in it. I do want to remove anything not needed though. I'm sure some of it is purposefully there for visual safety but not needed for imaging purposes. I consider it an imaging only filter for me and will never look through it.
Has thanked: 801 times
Been thanked: 928 times
Post by DeepSolar64 » Mon Feb 10, 2020 5:48 pm
Marty,
Thanks for the view I couldn't get yesterday. Awesome resolution!
Has thanked: 419 times
Been thanked: 219 times
Post by ffellah » Mon Feb 10, 2020 8:07 pm
Beautiful close-ups, Marty !
Has thanked: 1707 times
Been thanked: 662 times
Post by marktownley » Mon Feb 10, 2020 9:03 pm
Very nice images Marty!
mattwastell
Post by mattwastell » Fri Feb 14, 2020 8:11 am
Excellent edge shots - a treat for a Sun starved observer!
Matt Wastell
Look up, look good!
http://www.pbase.com/mattwastell
salvo lauricella
Has thanked: 56 times
Been thanked: 74 times
Post by salvo lauricella » Sat Feb 15, 2020 11:30 am
Excellent work Marty!
