25th March 2020 First light
Post by Montana » Wed Mar 25, 2020 3:11 pm
Well, this morning dawned clear blue sky so I was set up and waiting ready for the Sun to hit the telescope. I did the usual three lights looking for polar faculae, this may take me days to analyse again but the seeing was good, not marvellous but good. So from 11am I had a play with the Celestron C11 and my PST mod. I had no idea what I was doing and didn't expect to see anything at all because first lights are usually disasters.
ImageCelestron C11 Halpha by Alexandra Hart, on Flickr
This is the view at native, is this normal?
Sun_112825_25_03_2020_lapl4_ap4379 a.jpg (522.05 KiB) Viewed 346 times
Anyway, the view through a 2.5x Powermate was much more like what I see from you guys and this gave me encouragement. I didn't even think I would find the Sun, let alone focus it so I was very pleased with myself. Obviously seeing wasn't the best over lunch time but this gives me some hope so I am pleased to bits.
ImageSun_115953_25_03_2020 by Alexandra Hart, on Flickr
ImageSun_115953_25_03_2020 f colour by Alexandra Hart, on Flickr
ImageSun_122842_25_03_2020 by Alexandra Hart, on Flickr
ImageSun_122842_25_03_2020 f colour by Alexandra Hart, on Flickr
Equipment: Celestron C11 / Aries full aperture ERF / 2.5x Powermate / PST etalon / ASI174
rsfoto
Re: 25th March 2020 First light
Post by rsfoto » Wed Mar 25, 2020 3:14 pm
Very good and yes it takes time to get adjusted a new set up.
I was astonished how long that optical train is behind the scope :shock:
Post by marktownley » Wed Mar 25, 2020 3:49 pm
Weird, my seeing was pants today. The native view is showing the PST sweetspot, looks like in that view you've got it tuned as an annulus instead of a central spot, you can see how it goes off band at the edges of the fov. Barlowing / powermating into this centre of this is normal fodder on a pst mod. Glad you got a result, did you manage to do a comparison with the SF100?
Post by Montana » Wed Mar 25, 2020 4:31 pm
Thanks guys :)
Mark, yes, those are coming slowly :)
Starry Jack
Post by Starry Jack » Wed Mar 25, 2020 4:38 pm
There is going to be some gorgeous images coming from you soon! I can hunts of some really lovely high res features.
Aeries D-ERF
ZWO174 (IMX249 chip 5um)
JochenM
Post by JochenM » Wed Mar 25, 2020 4:55 pm
Impressive looking setup there, Alexandra. And nice results as well!
PS: I can imagine that actually finding the sun with that thing is not that straightforward.
Post by DeepSolar64 » Wed Mar 25, 2020 5:33 pm
Nice setup Alexandra!
Astrophil
Post by Astrophil » Wed Mar 25, 2020 6:06 pm
Coming along nicely, Alexandra. Fun and exciting times await you when the seeing improves. It only takes one great day to make it all worthwhile. You'll be ready.
Phil
Post by ffellah » Wed Mar 25, 2020 6:29 pm
Good first light, Alexandra. You will get great results soon with this set up.
eroel
Post by eroel » Thu Mar 26, 2020 2:50 am
Alexandra:
Beautiful setup, it takes time to tame it, so do not become impatient you will soon see spectacular results.
Best regards and keep healthy.
Post by Carbon60 » Thu Mar 26, 2020 6:49 am
Hi Alexandra,
When the seeing conditions improve you’ll get some fantastic images with this set up. I’ve found with mine if I add a red filter on the camera the contrast improves (I don’t know if this is an issue in your case). I alway use a PowerMate (2.5x or 5x depending on the conditions) as natural focal ratio imaging does not work so well. But then the idea is to use this for hi-res close views anyhow.
I always take and apply flats to eliminate dust bunnies, but then I also often apply a false flat during final processing to even out any gradients. Of course ‘seeing’ is the real killer, or maker, of excellent images. Some incredible sunspots wouldn’t go amiss either. :)
Lunt LS60THa B1200 PTFT
DMK41, Basler acA1920-155
NEQ6 Pro-mount
Post by Valery » Thu Mar 26, 2020 7:18 am
Hello Alexandra,
This is a good start. You can do this much easier and better if you will simplificate the etalon-filter-camera train.
See here how short and simple it can be.
adapter from PST etalon to telescope 2" visual back - adapter #1.
adapter 1 --> PST etalon with it's native lenses --> tube 140mm --> BF10 or BF15 --> barlow --> camera.
Total length is about 220mm only. Barlow magnification is depends of the camera pixel size and seeing. Not necessary to use too large focal length when you just trying to practice.
2x barlow shortened to screw-in in the nose of ASI174 camera is OK. It will give about 1,5-1,7x magnification and F/D=15-17 - absolutely enough for first experiments.
To adjust PST etalon for Ha better to make scale even smaller by binning 2x2. As Mark said already, you need to adjust PST etalon so that it will show a sweet spot of dark center with slow brightening of the sweet spot towards the outer edge.
This basically all.
Hope this helps.
__Alexandra C14 example2.jpg (193.71 KiB) Viewed 271 times
