I'm new to solar imaging and am using an ASI183 right now for full disc with a double stacked 75mm front mounted filters.
Setting gain as low as possible to keep the histogram around 80 to 90%, I end up with a gain of around 206 (45%) but am only getting fps ranges of 2 to 6. Comments on these settings and explanation of why I can get more FPS?
Thanks
ASI183 FPS and settings
- Has thanked: 173 times
- Been thanked: 615 times
Re: ASI183 FPS and settings
David,
I used an ASI 183MM on my SM60 DS/ ED80 for a while and returned it to ZWO due to "technical issues when imaging solar Ha". They supplied an ASI 1600MM in exchange.
I also use a x1.6 Barlow.
I use SharpCapture with a zero gain setting of 139 and a gamma of 50.
Vary the exposure to bring the histogram up to 85-90%
I can usually get around 12fps with a full frame, better if you ROI just the solar disk.
- PDB
- Has thanked: 2 times
- Been thanked: 149 times
the max fps range of the ASI183 in full resolution is 19fps. But you will need a fast computer and usb connection to get that. Also important for that is that USB limit is set at 100%. (But you risc dropping frames when your system can't coop)
You also did not specify exposure length setting. That is important too, because it limits the framerate. To slow and you can't get the 19fps anymore.
Rgrds,
Paul
Rgrds,
Paul
- Has thanked: 20424 times
- Been thanked: 10243 times
Where is this set Paul?
- PDB
Depends on the program used Mark.
In FC it's called USB Traffic (set in the Control window under the Gear Icon (More button)
In my old SharpCap is called Turbo USB
and in Genika under Options -> Performance -> Bandwith limit
P.
P.
- Has thanked: 146 times
- Been thanked: 277 times
I have a USB3 connection and USB speed is set at 100%.
I have been capturing for 60 seconds.
My laptop has 12GB of RAM. Do you think putting a SSD hard drive might help. My current one is certainly no great shakes.
- Has thanked: 17666 times
- Been thanked: 8787 times
I think I would check exposure time first, I very often find I can't get full fps because the exposure is too long and thus impossible to get full fps. What exposure time did you use for your capture?
- PDB
check what speed you get (fps) when capturing with and without saving to disk. If the speed is already bad (and loosing frames) without the capture active (saving) then the SSD does not help. If you ar use FireCapture you should set the buffering, that also helps. (under settings -> general-> use ram buffer) Mentions "experimental" but it works if you have memory avail.
If you see fps go down while you are capturing to disk, then an SSD is recommended. (In my system, which is desktop system I use one of these M2 SDD's with PCI (not SATA!) support. Speed is tremendous.
Paul
Paul
Great suggestions. Thanks.
I didn’t realize that the fps were limited by longer exposure times. With 5 ms exposures, I was averaging about 6 fps. With this setting, I had a gain of 45%. Is that alright? Wiith 10 ms , I was only getting 1 fps. I’ll check the speeds I’m getting with and without saving to disk.
