Motor driven helical focuser.
Rusted
Has thanked: 762 times
Been thanked: 211 times
Post by Rusted » Sun May 03, 2020 3:37 pm
This is nothing new but is very helpful on longer H-a telescopes when you can't take the imaging monitor to the focuser.
An "inexpensive" Skywatcher DC motor drives the helical focuser's knurled ring, by friction, via a timing belt.
A scrap of aluminium angle profile is clamped to the AOK Swiss etalon adapter and supports the motor.
I used a 20T timing pulley, 280t GT2 belt and 64mm Stainless steel hose clamps.
No tools were required other than a 5mm drill for the angle piece. Crude but effective.
https://youtu.be/_S2rpBx2zNI
P1410914 rsz 600.JPG (92.53 KiB) Viewed 488 times
Has thanked: 1614 times
Been thanked: 634 times
Re: Motor driven helical focuser.
Post by marktownley » Sun May 03, 2020 3:53 pm
Impressive, simple and effective. Looks like it works well! I like it!
rsfoto
Has thanked: 923 times
Been thanked: 679 times
Post by rsfoto » Sun May 03, 2020 5:40 pm
As Mark already said. KISS method.
hopskipson
Has thanked: 5 times
Been thanked: 3 times
Post by hopskipson » Tue May 19, 2020 1:11 pm
Very nice and simple design. You have inspired an idea I have. I want to motorize the "Richview" tuner on my Solarmax 90 DS etalon. Where do you find the parts like the motor, pulley and drive belt for your project? Thanks for the inspiration.
Martin_S
Has thanked: 47 times
Been thanked: 161 times
Post by Martin_S » Sat Jun 13, 2020 12:08 pm
I motorize all my focusers, here are this weeks cloudy sky projects. Most of my motor focusers cost around $7AUD to make . Mind you having a small lathe and milling machine does help a bit.
Martin
H - alpha setup
White Light setup
Skywatcher ED72 ,ED100, Homemade solar wedge, IR cut filter, Solar Continuum filter.
Mounts
Skywatcher HEQ5 Pro Mount ..
Darkside setup
Skywatcher ED72 ,ED100, GSO RC6 ,Celestron Nexstar 6SE.
