Processed images cannot be resized
DavidP
Has thanked: 170 times
Been thanked: 405 times
Post by DavidP »
Hi all. Sorry to ask so many questions, but I’m very new at all this.
As of this afternoon my computer will not let me resize any of the images processed after IMPPG. I’ve tried two different image converter programs and neither of them will even recognize the images. When I right click on the image and tried to resize, I get the message that I “do not have permission to change the image.”
Any idea on what has happened?
PDB
Has thanked: 2 times
Been thanked: 149 times
Re: Processed images cannot be resized
Post by PDB »
Hmmm, gonna need more details.
- What OS (i suppose windonws? but never seen resize when I right click on an image, but some programs can add functions to the right click options, so you never know)
- Format you saved the image in IMPPG (compressed tiff does not work with all programs)
- Short explanation of the workflow starting from IMPPG might help understanding.
Which image convertors did you try?
Rgrds,
Paul
Has thanked: 174 times
Been thanked: 622 times
Post by Merlin66 »
Download Irfanview.
This allows cropping and re-sizing of many image formats.
https://www.irfanview.com/
GreatAttractor
Has thanked: 762 times
Been thanked: 758 times
Post by GreatAttractor »
This sounds like a file permissions problem. If I had to guess, for some reason ImPPG is now launched in a compatibility (with an older Windows version) mode, runs with administrator permissions, and whatever files it saves are changeable by administrators - but not regular users. Can you delete those images, or does it also give an error message?
Try to right click such an image, choose "Properties", "Security", select "Users" in the upper list and see if "Allow: Write, Modify" are checked in the lower list - if not, the problem is indeed with permissions.
My software:
My images
