21May - C11 HA/CAK Close-ups - Images added 23 May 20
Has thanked: 185 times
Been thanked: 178 times
Re: 21May - C11 HA/CAK Close-ups
Post by Carbon60 » Fri May 22, 2020 5:42 pm
This is certainly great information. Thanks for the discussion, guys.
Lunt LS60THa B1200 PTFT
DMK41, Basler acA1920-155
NEQ6 Pro-mount
yltansg
Has thanked: 135 times
Been thanked: 60 times
Post by yltansg » Sat May 23, 2020 11:03 am
Filip (GreatAttractor) processed another raw file, different from the image posted previously but taken on the same day 21 May (from stacking 500 frames) with ImPPG to produce this image (500frames - 70%, Q117)):
At 100% Q was 123
Subsequently, using the same ImPPG processing settings to process a 1000 frame, 1500 frame and 2500 frame image:
1000-frame stacking (63%, Q115)
1500-frame stacking (58%, Q114)
and finally 2500-frame stacking (52%, Q113)
All these images look about the same to me. There is no improvements in terms of details and also no significant blurring because of more frame stacking. Please give me your views. Next I will explore doing more stretching in ImPPG on the images with more frames to see if I can get more details out of them.
With Filip's permission I have attached his XML file for those who are keen to know.
Alfred
cak_proc.xml
(420 Bytes) Downloaded 7 times
krakatoa1883
Has thanked: 23 times
Been thanked: 65 times
Re: 21May - C11 HA/CAK Close-ups - Images added 23 May 20
Post by krakatoa1883 » Sat May 23, 2020 11:46 am
Alfred, can you share the raw ?
yltansg
Post by yltansg » Sat May 23, 2020 11:52 am
Hi Raf,
Here they are:
092201 1000c1exp057.png (2.89 MiB) Viewed 97 times
092201 1500c1exp057.png (2.86 MiB) Viewed 97 times
yltansg
Post by yltansg » Sat May 23, 2020 11:55 am
Here is the raw for the 500 frame-stack
092201 500c1exp057.png (2.97 MiB) Viewed 96 times
solarGain
Been thanked: 31 times
Post by solarGain » Sat May 23, 2020 3:22 pm
Alfred, there is a lot going on here.
John
dhkaiser
Has thanked: 236 times
Been thanked: 139 times
Post by dhkaiser » Sat May 23, 2020 5:34 pm
h-alpha shot with good resolution!
Dan
Lunt LS60THa
Lunt LS60FHa DS
Ioptron AZ Pro mount
ASI 178 mono
South central Indiana
USA
krakatoa1883
Post by krakatoa1883 » Sat May 23, 2020 6:05 pm
Unfortunately I could not do anything better with your raws than GreatAttractor already did. However at that image scale I think you need a really excellent seeing to obtain good images. Why don't use a stronger reducer ?
yltansg
Post by yltansg » Sun May 24, 2020 2:16 pm
Thanks John and Dan for your kind words.
Krakatoa, Thanks for trying. For now, I don't think the solution is better image post processing.
I will be trying different configurations (with different CAK filters) to see what is the best I can get out of the C11 + ARIES D-ERF. Will post my findings.
Alfred
