Active region on May 22
gabrieli
Been thanked: 41 times
Post by gabrieli » Fri May 22, 2020 9:30 pm
There wasn't much improvement in seeing from last day, but the active region made up for it.
I used my 7" inch Mak again, this time in double stack mode using a 35 nm Ha filter + 2X Powermate + LS50F +
+ Quark Combo + tilter + 0.5X reducer + Blackfly S (3.2Mp). This gave an efl of about 2700mm, probably a bit high for the conditions (only one image out of a dozen was acceptable).
The module itself is heavy. I hesitated to switch the order of the two etalons. The 2X Powermate seems able to support the LS50F + the rest of the image train. I also feel more comfortable that the image train is nearly vertical to reduce the tendency to "flex".
My c9.25 will produce a smaller image scale than this 7 inch with the same double stack module
(2300mm instead of 2700mm). I'll try that scope next time.
Lou
Ha mod.JPG (1.57 MiB) Viewed 149 times
p_zetner
Has thanked: 2 times
Been thanked: 31 times
Re: Active region on May 22
Post by p_zetner » Fri May 22, 2020 9:40 pm
Nice image, Lou.
Should be a promising combination under good seeing conditions.
What is the focal ratio at the LS50?
Peter
gabrieli
Post by gabrieli » Fri May 22, 2020 9:59 pm
Hi, Peter
Your question made me realize that there was an error in my figures. I was thinking of the 3X telecentric I had used the other day instead of the 2X Powermate I used for the current images. I corrected the efl values in this post.
The 7 inch Mak has a "prime" focal length of 2700 mm at f/15. I used the 2X Powermate as a telecentric which gives an efl at the LS50F of 5400 mm at f/30. The 0.5X reducer brings it back to 2700 mm.
Lou
EGRAY-OBSERVATORY
Been thanked: 44 times
Post by EGRAY-OBSERVATORY » Fri May 22, 2020 10:12 pm
Hi Lou,
Those two images must be near the limits of how apparently close to the surface we can get from terra-firma.
With the set-up you are using as well as 2700mm too, is something to make me jealous, but very well done.
Clear Skies.
Been thanked: 172 times
Post by eroel » Fri May 22, 2020 11:13 pm
Lou:
Very nice results.
Has thanked: 204 times
Been thanked: 194 times
Post by Carbon60 » Sat May 23, 2020 6:29 am
Very nice fine details, Lou. This will be a stunner under ideal seeing conditions.
Lunt LS60THa B1200 PTFT
DMK41, Basler acA1920-155
NEQ6 Pro-mount
yltansg
Has thanked: 172 times
Been thanked: 72 times
Post by yltansg » Sat May 23, 2020 6:42 am
Hi Lou,
Very nice HA close-up with that extremely long imaging train!
Alfred
GreatAttractor
Has thanked: 34 times
Been thanked: 9 times
Post by GreatAttractor » Sat May 23, 2020 7:52 am
That's a great result and an interesting setup! I loved my former SW Mak 180 for white light work, but didn't see an easy way to use it for Hα. I may revisit it in the future (perhaps a Quark Combo?).
Do you perhaps have some images made with only the Mak + TV2x + LS50F?
My software:
My images
Has thanked: 637 times
Been thanked: 221 times
Post by Montana » Sat May 23, 2020 10:54 am
Stunning images Lou, I look forward to more :bow :hamster:
dhkaiser
Has thanked: 249 times
Been thanked: 152 times
Post by dhkaiser » Sat May 23, 2020 12:27 pm
Yes extremely long imaging train, nice job.
Dan
Lunt LS60THa
Lunt LS60FHa DS
Ioptron AZ Pro mount
ASI 178 mono
South central Indiana
USA
solarGain
Post by solarGain » Sat May 23, 2020 3:12 pm
Excellent images Gabrieli. I must get around to imaging in Ha!
John
Has thanked: 807 times
Been thanked: 310 times
Post by marktownley » Mon May 25, 2020 11:26 am
Very impressive Lou!
