PST Etalon Adjustment PIN
Solar B
Has thanked: 22 times
Been thanked: 11 times
Post by Solar B » Tue Jun 09, 2020 6:54 pm
Ah don’t know what I’ve done here !
But it’s one of those I wish I’d left alone !
I took of the rubber grip to expose the small
screw and loosened it ... now the tilt will go
a long way and won’t stop plus I can’t seem
to be able to relocate the small screw into
any location where it will take hold.
Solar B
Re: PST Etalon Adjustment PIN
Post by Solar B » Tue Jun 09, 2020 11:21 pm
It's ok I'm a wassock as I hadn't pulled the plate forward 🙄
Rusted
Has thanked: 762 times
Been thanked: 211 times
Post by Rusted » Thu Jun 11, 2020 7:59 am
I leave my PST etalon open. No shell nor ribbed rubber band. I use a watchmaker's screwdriver in one of the [screw] drive holes.
Then I can both tune and tilt the etalon ring gently sideways for the most even brightness and surface clarity across the field.
It is probably a bit silly because dust can get inside onto the etalon's outer surface. Though I could use my bulb, dust blower for that.
Starry Jack
Has thanked: 59 times
Been thanked: 76 times
Post by Starry Jack » Thu Jun 11, 2020 7:48 pm
Rusted,
I do the same thing except I put electrical tape over the holes that do not have the screwdriver in them.
Aeries D-ERF
ZWO174 (IMX249 chip 5um)
Rusted
Post by Rusted » Sat Jun 13, 2020 9:32 am
Rusted,
Is this just to avoid tuning off band?
Or is there some other reason?
Has thanked: 1614 times
Been thanked: 634 times
Post by marktownley » Sat Jun 13, 2020 8:48 pm
Did you sort this Brian?
Starry Jack
Post by Starry Jack » Sat Jun 13, 2020 11:43 pm
The electrical tape is simply to keep dust out of the holes. I meant I do the same thing with no rubber ring and using a small screwdriver as the long lost screw.
Aeries D-ERF
