Ah don’t know what I’ve done here !
But it’s one of those I wish I’d left alone !
I took of the rubber grip to expose the small
screw and loosened it ... now the tilt will go
a long way and won’t stop plus I can’t seem
to be able to relocate the small screw into
any location where it will take hold.
PST Etalon Adjustment PIN
- Has thanked: 22 times
- Been thanked: 11 times
- E671B940-0012-4397-AD5C-069BDD11F2BF.jpeg (1.71 MiB) Viewed 2459 times
- AF16CFA8-0F16-45D4-BF34-513348F2C88D.jpeg (1.41 MiB) Viewed 2459 times
- 917595B8-4C81-41A1-AD22-08A6AABF351E.jpeg (1.31 MiB) Viewed 2461 times
- Rusted
- Has thanked: 8114 times
- Been thanked: 1941 times
Re: PST Etalon Adjustment PIN
I leave my PST etalon open. No shell nor ribbed rubber band. I use a watchmaker's screwdriver in one of the [screw] drive holes.
Then I can both tune and tilt the etalon ring gently sideways for the most even brightness and surface clarity across the field.
It is probably a bit silly because dust can get inside onto the etalon's outer surface. Though I could use my bulb, dust blower for that.
- Has thanked: 141 times
- Been thanked: 240 times
Rusted,
I do the same thing except I put electrical tape over the holes that do not have the screwdriver in them.
Aeries D-ERF
12nm Filter
ZWO174 (IMX249 chip 5um)
Aeries D-ERF
12nm Filter
- Rusted
Is this just to avoid tuning off band?Starry Jack wrote: ↑Thu Jun 11, 2020 7:48 pm Rusted,
Or is there some other reason?
- Has thanked: 20732 times
- Been thanked: 10427 times
Did you sort this Brian?
The electrical tape is simply to keep dust out of the holes. I meant I do the same thing with no rubber ring and using a small screwdriver as the long lost screw.
Aeries D-ERF
12nm Filter
Aeries D-ERF
12nm Filter
