Solar Animation Tutorial (June 2020)
Moderator: marktownley
- Has thanked: 8588 times
- Been thanked: 8324 times
There are various ways of doing solar animations and there are already a few excellent tutorials on SolarChat. Here's another option that I use, employing AS!3, ImPPG and GIMP applications that are all free to download.
I'm sure that some of you will have other tricks and tips to share, but for anyone new to this I hope you find my approach to be of some guidance, along with the other methods on this site.
If you try this, please let me know if I've missed any important steps or made any glaring errors so that I can correct accordingly
Thanks.
Thanks.
- Has thanked: 20938 times
- Been thanked: 10586 times
Re: Solar Animation Tutorial (June 2020)
A great resource Stu! lets have a bit of discussion here and then will put in the solar library.
- GreatAttractor
- Has thanked: 748 times
- Been thanked: 757 times
Great tutorial, Stu!
As for coloring the whole animation in GIMP, I've read there are scripts to automate it (i.e apply Curves/other operations to all layers), but haven't got around to trying it.
I noticed you have "CPU + bitmaps" mode enabled in your ImPPG screenshot. Do you get an error message or graphical artifacts when using GPU/OpenGL mode? If so, updating the graphics driver should help.
- Has thanked: 9379 times
- Been thanked: 6198 times
- Been thanked: 5015 times
- Has thanked: 9807 times
- Been thanked: 5822 times
Hi Stu,
Thanks for the tutorial. Will try the Alignment procedure of ImPPG.
- JochenM
- Been thanked: 1619 times
Thanks, Stu.
Also, I somehow always managed to overlook the batch processing option in ImPPG
- marios i.
- Has thanked: 1707 times
- Been thanked: 1125 times
Thank you!
Marios S.Ioannou
Sketcher/Visual Observer
Hi,GreatAttractor wrote: ↑Sun Jun 21, 2020 9:30 am I noticed you have "CPU + bitmaps" mode enabled in your ImPPG screenshot. Do you get an error message or graphical artifacts when using GPU/OpenGL mode? If so, updating the graphics driver should help.
No problem running in either mode (no error messages), but I find in GPU mode the image has 'lower resolution' than in CPU+bitmaps mode, as shown in the examples below (magnified views of identically processed Ca K image). Are the features visible in the GPU image the graphical artifacts you mention?
- GreatAttractor
I haven't seen this one before, but yes, it looks like the cubic interpolation shader isn't executing exactly how it should on your setup. I'm guessing the saved processed images look the same though for both back ends? Could you send me the stack and ImPPG settings file so I can check on my system?
Thank you Stuart. Will be useful in due course.
Regards
Regards
