ImPPG 0.6.2 - Russian and Ukrainian translations
GreatAttractor
Has thanked: 747 times
Been thanked: 757 times
Post by GreatAttractor »
Thanks to Rusłan there are now Russian and Ukrainian translations:
Version 0.6.2 can be downloaded from: https://github.com/G.../imppg/releases
My software:
My images
EGRAY_OBSERVATORY
Been thanked: 4900 times
Re: ImPPG 0.6.2 - Russian and Ukrainian translations
Post by EGRAY_OBSERVATORY »
Thanks for the post - GreatAttractor.
If you can please, can you post here the exact web-address, so I can download IMPPG for a Windows 8.1 - 64bit PC.
I have tried several-times to download this program (which advice from SolarChat member has advised), but the download-system from the web-links is not obvious and less than easy to do..
Your help would be appreciated - thanks
Regards
EGRAY OBSERVATORY
EGRAY_OBSERVATORY
ALSO, I should have mentioned that the English language version is required - please ?
Thanks vm
EGRAY OBSERVATORY
GreatAttractor
Hi Terry,
Here's the Releases page: https://github.com/GreatAttractor/imppg/releases
You want the latest (v. 0.6.2) imppg-win64.zip file: https://github.com/GreatAttractor/imppg ... -win64.zip
On first start, the language is set to English (or to Polish/Russian/Ukrainian, if one of them is your current system language - which probably doesn't apply; it can be always switched later).
Don't forget to have a look at some tutorials: "Useful links" on the homepage.
My software:
My images
EGRAY_OBSERVATORY
Ok on your reply and many thanks for the quick response.
Will be trying tonight or tomorrow.
Best Wishes
regards
EGRAY_OBSERVATORY
I have tried your suggestion, but again it won't install properly on my pc as a Windows 8.1 64-bit machine.
The program is missing drivers or something else.
Will get my IT adviser to try once, as this program seems to have an ancient-method of installation, or otherwise it cannot be used...
Thanks anyway
GreatAttractor
In case there are any error messages/pop-ups after you unzip the downloaded file and then try to run imppg.exe, please post them here.
My software:
My images
EGRAY_OBSERVATORY
Thank you again and will have to leave this to my IT adviser to try and get it installed as soon as he is available, where he can remotely control my pc.
I will get the adviser to read your suggestions...
Best Wishes
EGRAY_OBSERVATORY
Thanks again for your recent advice on the installation of IMPPG, where my IT expert successfully downloaded it yesterday and apparently can only be run from the Downloads folder, rather than my expected full-installation on the PC's hard-drive.
I will start trying it out shortly, as a new-pc is about to be installed and programmed in the observatory - to replace a faulty-pc and then tested for the various cameras and remote tracking etc...
Thanks again.
Regards
