Lunt 80mm + Refractor 150. Need Help guys.
Hi, i wanna coonect my 80mm lunt ethalon to refractor 150mm ( think about Sky-Watcher 150) for more aperture. So i need Erf 150mm+refractor 150mm+ ring for connecting ethalon and tube? Lunt 80 (1800bf+Crayfrord)
- _Zakalwe
- Has thanked: 68 times
- Been thanked: 56 times
Re: Lunt 80mm + Refractor 150. Need Help guys.
Are you trying to replace the objective on an existing Lunt solarscope or trying to mount a Lunt 80mm external etalon to a refractor?
You could use a smaller ERF mounted inside the OTA. As long as the light cone is contained within the diameter of the ERF then that could suffice.
How to find the correct spacing for the Lunt though is another matter. You'll also need a blocking filter
- Been thanked: 10489 times
Do you have the Lunt80 scope?
