I'm planning to mod my Lunt 50 over the winter. Hey, you got to keep your mind busy in these covid times!
Seeing isn't fantastic where I live, so I'm thinking a 80-100mm mod. At this aperture, I seem to get away with just using an internal 2" IR/UV cut filter? I have both the Baader 7nm and 35nm H-alpha filter, if that is better/makes any difference.
OK, let's talk focal ratio. How close do I have to be to F7? I have seen people using F5-F10 without much trouble. I already own a Esprit 80/F5 apo, so it would be nice to be able to use that (can a triplet be damaged by heat?)!
Going from a 80mm F7 to a 102mm F7 means a "big" jump in size and bulk. So then part of me is going; "go for a 152/900"
Right now I am looking at a non-destructive mod, like the one seen here:
https://imagesofoursun.wordpress.com/eq ... -achromat/
BTW, is there a special distance I need to put the IR/UV filter at? In the mod above, the filter is close. But I have seen other mods where the filter is further up the tube.
So mod gurus, hit me with some knowledge!
