Solar Spectroscopy
- Has thanked: 9243 times
- Been thanked: 5504 times
Solar Spectroscopy
I dusted off my good old LISA Spectrograph and I will start again doing spectroscopy but mainly stars, nebula and night time objects.
As a member of Spectro ARAS I just read about the new development from Christian Buil called Sol'EX a 3D printed solar spectrograph and it looks very interesting.
For all those being a member of Spectro ARAS you can read it here
http://www.spectro-aras.com/forum/viewt ... 094#p15094
Also in Astrosurf he presented the new Spectrograph
http://www.astrosurf.com/topic/142370-l ... -de-solex/
So far nothing is on his website yet http://www.astrosurf.com/buil/index.html
Here some images of it.
BTW just as an add on here a spectrum of a Nova in Perseus called Nova Per 2020 which I took on the night of December 3 2020
- Has thanked: 17533 times
- Been thanked: 8763 times
- Has thanked: 17458 times
- Been thanked: 16562 times
Re: Solar Spectroscopy
And does anyone make a commercial ready-to-use solar spectroscope?
- Has thanked: 8355 times
- Been thanked: 8103 times
Thanks, Rainer.
I’m just finishing off my redesigned solar spectrometer, which I hope to give a test run next time we get some Sun here.
Hi Alexandra,
I do not have a 3D printer. Some friends do have one but the printing quality is not good. I have a few pieces but honestly do not like the quality.
The point is not the 3D printer but to leran how to make the necessary files for 3D printing and so far I ahve not understood it yet
Hi Stu,
Waiting to see the results. Would you please post an image of your Solar spectroscope ? Thanks
Hi James,DeepSolar64 wrote: ↑Sun Dec 06, 2020 7:15 pm And does anyone make a commercial ready-to-use solar spectroscope?
Well the question here is if just a Solar spectroscope like this one
https://www.shelyak.com/solar-spectrum- ... 2/?lang=en
or a solar spectrohelioscope https://en.wikipedia.org/wiki/Spectrohelioscope in order to scan line wise the sun and build up an image ...
I have no experience in this regard and how this works but there is a wealth of info in the WWW
Shelyak is the best developped company so far as I know with this type of products in the wallet range of amateurs.
Here is a spectrum of the Sun which I took with my slit spectrograph from Shelyak model LISA
The blue line is a professional spectrum and the red is my result. This is more or less a star spectrum.
I'm guessing that the extra absorption dips you get are from our atmosphere?
Hi Alexandra,
Our atmosphere starts after 6800 Ångström
- Has thanked: 173 times
- Been thanked: 615 times
Any slit spectrograph can be used to obtain a solar spectrum.
Just need to point it to a bright sky - no telescope required.
Add it to a telescope and you have a spectroheliograph.
To obtain spectrogram images, you scan the slit across the solar disk, select and isolate the line of interest ( CaK, Fe, Mg H beta, H alpha etc.) and extract and combine using Wah! Spectral line merge program.
Hi Ken,Merlin66 wrote: ↑Mon Dec 14, 2020 2:42 am Any slit spectrograph can be used to obtain a solar spectrum.
That sounds good but
I guess I need an ERF in order to protect the Heat production or not ?Add it to a telescope and you have a spectroheliograph.
Rainer,
No ERF used.
The telescopes used are generally smaller refractors 100- 120mm.
We want to get as much light as we can through the very narrow slit gap and use very fast frame rates.
The heat build up on the slit plate doesn't appear to be an issue.
No ERF used.
Hi Ken,
I have a Takahashi TOA 130 in front of my LISA ...
This for me is already a suggestion not to try it ... so I better do not do it... slit plate doesn't appear to be an issue.
You could use (with a significant light loss) a Baader ND3.8 solar filter on the aperture.
Then you have absolutely no issues with possible heat loading.
An alternative would be to stop the aperture down to 60mm with a card disk/ ring.
The SimSpec SHG V1.3 allows you to assess the probable performance of the SHG.
Just a hint to new SHG users.....
How do you know if your slit gap is at the focus of the telescope?
Normal method is to check the top/ bottom edges of the solar spectrum being recorded. When in focus, they should appear tight and crisp.
A quick way to get you close....
Use a finder to look through the objective and check that the slit gap appears in clean focus.
Helps during initial set-up.
