Hi all.
LZOS 6 "f8 Apo, TV 4x Powermate, GKC ADC, ASI290mc + UV / IR blocking filter
Greetings from Switzerland
Jozef
Mars 2020
Moderator: Montana
Re: Mars 2020
Wow! it is getting much smaller very quickly, I didn't expect that, although I should have
- Has thanked: 8558 times
- Been thanked: 8290 times
Re: Mars 2020
Fascinating to see the changes, Jozef.
Excellent work.
Excellent work.
Re: Mars 2020
Jozef/Alexandra, Sounds interesting. Which one, specifically?
- oreoluna
- Been thanked: 661 times
- oreoluna
Re: Mars 2020
Hello Alexandra.
When I saw the documentary, I was sure it was you. Your look very similar, and your names are "almost" the same ...
Well, it was a mix-up.
CS Jozef
CS Jozef
- Been thanked: 4427 times
Re: Mars 2020
Hi Jozef...
Your images of Mars this fall have been exceptionally sharp...very well done
