Hi Folks,
On a chilly clear sky evening here's an enhanced colour image of the Moon.
20210123_Moon_Colour by Stuart Green, on Flickr
I was lucky because the clear sky didn't remain clear for long. No thick clouds at the time of posting, but lots of haze/fog as the temperature dropped into the night.
Thanks for looking.
Reflected Sunlight 77% Waxing Gibbous Moon
Moderator: Montana
- Has thanked: 8544 times
- Been thanked: 8281 times
- Been thanked: 4423 times
Re: Reflected Sunlight 77% Waxing Gibbous Moon
Great shot Stu
Nice to see you caught it when you could.
It was to be clear here overnight, but it has managed to cloud over at sunset. If it clears it will be cold btu will go out if I can.
- Been thanked: 8905 times
You are brave Stuart, but this is a cracking image
Yes Stu - a 15 out of 10 image - showing the delicate colours of our nearest neighbour.
Thanks vm for suffering the cold for this beautiful image...
Many thanks, Brian, Alexandra and Terry.
- Has thanked: 9307 times
- Been thanked: 6144 times
Stu, I really like the image, colors are excellent! Thanks for the inspiration.
Phil
Phil
Many thanks, Franco & Phil.
Phil, It's something I'd been thinking of doing for quite some time, but only recently did I get around to giving it a go. My results have been a bit hit and miss depending on the conditions and my technique.
