Can I mod my Lunt 2inch hershal wedge?
Stardust5858
Has thanked: 803 times
Been thanked: 1182 times
Post by Stardust5858 »
Hi all, I want to use a 1.8nd in my Lunt 2ich hershal wedge instead of the 3nd which is glued in place. Is there any way to get this filter out or is it a question of hitting it and destroying the filter? I've a current baader k- line that I could do with extra light to reduce frame rate. I can easily buy a new 3nd filter if I wish to use visually but I don't do visual hardly ever.
Am I mad to do this?
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Has thanked: 64 times
Been thanked: 4406 times
Re: Can I mod my Lunt 2inch hershal wedge?
Post by MapleRidge »
Nigella...
I can't comment on the ability to remove the ND filter, but just want to double check your plan for the mod.
You are wanting to allow more light through to image with the K-Line filter, but add in an appropriate ND filter for WL visual/imaging? Is that right?
Stardust5858
MapleRidge wrote: Fri Feb 12, 2021 11:46 pm Nigella...
Hi Brian, yes, but 95% imaging, don't really do visual and happy with the mod being used solely for imaging. I think with the Lunt wedge it works out at 5ND with the installed 3ND. Recommendations for imaging with the baader k-line is 3.8ND. So I'd like to take out the 3.0ND and replace with a 1.8ND thus giving me a total output of 3.8ND. Does that make sense?
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Has thanked: 20738 times
Been thanked: 10432 times
Hi Nigella.
REally easy, just unscrew the 2" ep holder from the top, you will need to replace it with one without the filter, if memory serves is a 2" sct thread. I've done exactly the same as you with my Lunt wedge for exactly the same reasons.
You might get away without using a ND filter at all when imaging with the K-line for really short exposure time, try it.
Stardust5858
marktownley wrote: Sat Feb 13, 2021 8:07 am Hi Nigella.
Thanks Mark, really appreciate this, good idea.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Stardust5858
Just an update. The retaining ring on the inside of the eyepiece holder was easy to undo and remove the ND3 filter completely. I now can use the hershal wedge for imaging without an ND filter or with a recently bought ND1.8 filter. It turned out to be really easy to change the ND filter.
Thanks again all who replied.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Interesting, the retaining ring in mine was jammed solid and I risked damaging the ND3 to get it out, good to know it is an option in some situations.
