Coronado BF10 straight-through conversion?
Gingerfish
Has thanked: 60 times
Been thanked: 78 times
Post by Gingerfish »
Since I only image, having a straight-through version of my BF10 would be nice. Has anyone in here done this? On paper, it seems pretty straightforward. But I bet it's not, or more people would have done it! :D
Clear sunny skies!
Chris
Lunt LS50THa
Lunt "Luntair" Altair 102ED
Has thanked: 20442 times
Been thanked: 10248 times
Re: Coronado BF10 straight-through conversion?
No reason why not!
MalVeauX
Has thanked: 1171 times
Been thanked: 1360 times
Post by MalVeauX »
Yeap, its fine to do. There's nothing special going on with the diagonal. It's a basic star diagonal. The eyepiece side has the blocking filter. It's usually glued on (the 1.25" nose is glued, you'd have to break that adhesive to unthread it).
I converted one to straight through and even added a helical focuser to it, just to have more options to play with distances.
Stardust5858
Has thanked: 803 times
Been thanked: 1182 times
Post by Stardust5858 »
Just wondering if this can be done with the Lunt wedge too.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Stardust5858 wrote: Sat Feb 13, 2021 2:48 pm Just wondering if this can be done with the Lunt wedge too.
No, with the Lunt wedge the filters are mounted in the diagonal body rather then the nosepiece sections.
Stardust5858
marktownley wrote: Sat Feb 13, 2021 3:07 pm
Thanks Mark, good to know.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Gingerfish
OK! How long does the adapter have to be?
Thanks guys!
Clear sunny skies!
Chris
Lunt LS50THa
MalVeauX
Post by MalVeauX »
Gingerfish wrote: Sat Feb 13, 2021 6:56 pm OK! How long does the adapter have to be?
Thanks guys!
Shouldn't matter, there's no optics that re-focus the light cone, just passes it through. Ideally make it as short as possible, but without masking the light cone. It's always easier to get distance out of the focuser, than back focus into the focuser.
Here's a straight through conversation and I even added a helical focuser:
Here's the BF retro fitted into an eyepiece barrel basically (or the 1.25" nose of any diagonal):
Gingerfish
Excellent! :D
Clear sunny skies!
Chris
Lunt LS50THa
