OTA baffle hack for easy filter / optic install ; internal Ir/UV - plano concave
- Has thanked: 20424 times
- Been thanked: 10243 times
Re: OTA baffle hack for easy filter / optic install ; internal Ir/UV - plano concave
Solutions is what it's all about. Yup, I can see how that would work.
- Has thanked: 1171 times
- Been thanked: 1360 times
This looks interesting.
I have an ST80 with 2" focuser (80mm F5). I'll check it out.
What's the max size this could be setup for, to do a full disc with a PST etalon well within the entire sweet spot?
- Been thanked: 4340 times
I used this method to mount the 110mm D-ERF inside the tube of the 150mm Celestron refractor that I modified.
As you say, works like a charm.
I will work on getting some updated pis and post them in the mods section. Might take a few days...really busy around home setting up syrup equipment in the sugar bush the past few days and through the weekend.
