A fairly even/uneventful month as far as meteor detections go. Will probably stay that way until the Lyrids in April.
Radio meteor detection - Feb 2021
- JochenM
- Been thanked: 1619 times
- Has thanked: 18114 times
- Been thanked: 8943 times
- Has thanked: 9833 times
- Been thanked: 5844 times
Re: Radio meteor detection - Feb 2021
Hi Jochen,
Well done and yes nothing spectacular in February and March seem to be even worse according to Meteor News.
Which program do you use for making those graphs ? Which file do you use ¿ RMOB_YYYYMM ?
Thanks Rainer
Thanks Rainer
- JochenM
Hey Rainer.
It's a simple spread sheet graph (LibreOffice Calc). I take the monthly .dat file indeed, feed it into a spread sheet as comma separated data (so ending up with three columns of data).
After that, just insert a graph. Column 1 (date/time) populates the X-axis, column 3 (the hit count) goes to the Y-axis and that's it.
Ah, OK. I was a bit confused about the first column with the data YYYYMMDD## ... I guess they included the numbering after the date of each day and only so it is possible to make a clear X horizontal axis.JochenM wrote: ↑Mon Mar 01, 2021 5:22 pm Hey Rainer.
Will try it. I do use OpenOffice
Thanks Rainer
- Has thanked: 8596 times
- Been thanked: 8328 times
Welcome to the club, Jochen
Yes, February (and March as Rainer also says) are quiet months, but at least you’re up and running.
- Has thanked: 20977 times
- Been thanked: 10601 times
Thanks Jochen!
