Moon, February 27th, 2021
Lets brighten up peoples live with all those lovely pictures of the world around us!
Moderator: Montana
LTHB
Been thanked: 581 times
Post by LTHB »
Having seen all these pretty moon pictures here I decided I had to give it a try myself. Capturing the full moon was pretty easy, and stitching together a mosaic quickly with ImageCompositeEditor worked for the first time for me (it never did with solar mosaics). I found sharpening quite a challenge: It is really hard to avoid ringing artefacts without ending up with somewhat blurry images.
It's just black and white, however, but I have to try RGB, like Phil and Rainer when the weather allows.
Kind regards,
Frank
Has thanked: 64 times
Been thanked: 4427 times
Re: Moon, February 27th, 2021
Post by MapleRidge »
Great lunar mosaic Frank...well done :bow
Has thanked: 17974 times
Been thanked: 8906 times
That's a really good one :bow :hamster: I know what you mean, sharpening the Moon is very difficult, it makes you wonder what we are doing with the Sun ;)
Astrophil
Post by Astrophil »
Frank, very good moon shot. Exposure, detail, and stitching is excellent. Just needs a little color. Maybe on the 28th?
Phil
Has thanked: 8558 times
Been thanked: 8290 times
Post by Carbon60 »
Nicely done, Frank.
Has thanked: 9319 times
Been thanked: 6157 times
Post by ffellah »
Your moon came up really well, Frank !
LTHB
Post by LTHB »
Thanks everybody!
Taking a second look at my picture the processing could clearly be improved on several counts. Maybe I'll do a version 2.0 if I find the time in the next days.
Alexandra, exactly my sentiments about sharpening! I often wonder how much of the crisp CaK structures in my solar images may be just sharpening artifacts and how much of the soft boundaries of my h-alpha structures may be too blurry. For the moon it is easier to tell.
rsfoto
Has thanked: 9723 times
Been thanked: 5773 times
Post by rsfoto »
Montana wrote: Mon Mar 01, 2021 3:31 pm That's a really good one :bow :hamster: I know what you mean, sharpening the Moon is very difficult, it makes you wonder what we are doing with the Sun ;)
Well sharpening any image is not easy and mostly makes it more difficult if the RAW material is not at its best focus point.
What is sharpening really ? IMHO it is not more then applying a bit more contrast to an image. Easy as that :mrgreen:
rsfoto
Post by rsfoto »
I contacted Frank in private in regard to his Moon image.
I have seen many many images in Solarchat which could easily be improved by the simple trick of taking a look at the histogram. I think I already mentioned it once but people tend to ignore this basic tool of Level Control and I guess they do because the tool is so simple that they say it can not improve my image. In this case less is much much more :mrgreen:
Histogram stretch is about making Black Black and White White and lift the the details in the Shadows which are the Middle tones. IMHO
I did send to Frank the following analysis by taking a look at both images and think about it. OK, it is not the Holy Grail solution but brings you a big step further. IMHO
