roll-off-roof observatory | Pedro RE'
Lets brighten up peoples live with all those lovely pictures of the world around us!
Moderator: Montana
pedro
Has thanked: 14 times
Been thanked: 6686 times
Post by pedro »
roll-off-roof observatory | Pedro RE' (2021)
TEC140 F/7 | PARAMOUNT ME | ALTA APOGEE U8300
TEC140 ALTA APOGEE U8300
roll-off-roof observatory | Pedro RE' (20201120)
First Light TEC140 ALTA APOGEE U8300 | M33
Roll-off-roof observatory | Pedro RE' (20201031)
Observing the Sun
Roll-off-roof observatory | Pedro RE' (20201029)
EGRAY_OBSERVATORY
Been thanked: 4900 times
Re: roll-off-roof observatory | Pedro RE'
Post by EGRAY_OBSERVATORY »
Thank you Pedro for the fab videos.
The RO/RO roof is so simple to to use and compared to mine is just absolutely fab, as your weather is usually too.
(Mine though, has to be able to carry the total-weight of the tri-scope assembly on occasions from the mount to a moveable trolley, which is far easier than having separate and re-aligning the three scopes etc... There is a winch-pulley system in place from the roof structure, which was part of the original design..)
Regards
pedro
Post by pedro »
Thanks Terry
The roof of the second roll-off is very light and simple to use. My older roll-off, built in 1978, has a heavier roof that is not easy to move.
Roll-off-roof Observatory | Pedro RE' (2019)
Has thanked: 64 times
Been thanked: 4407 times
Post by MapleRidge »
Pedro...
The videos of your roll off are great to view. You are fortunate that your roof structure is so light... I need more structure to carry the snow loads. Frost over the years has heaved some of the structure of the large roll-off and a winch is needed do roll it now (23 years in use).
pedro
Post by pedro »
