Hello, could someone help me with this problem?
The system consists of Coronado SolarMax III 90mm f / 8.8 Double-Stacked H-alpha Solar Telescope 15mm Blocking and an ASI 183 MM camera.
When I increase the gain of the camera or increase the exposure time to capture the solar prominences, a grid pattern appears in the image like the one in the photo.
ZWO 183
- Has thanked: 9723 times
- Been thanked: 5773 times
Re: ZWO 183
Is the image in the screen at 100% size ? For better appreciation please post the full screen shot and best is to use the snipping tool ...
At a certain zooming value there can appear a so called Moiré effect which could make similar things like you see or maybe better said interference patterns between the monitor and the image ...
https://en.wikipedia.org/wiki/Moir%C3%A9_pattern
- Been thanked: 10489 times
Re: ZWO 183
Hi there and welcome to the forum!
183s do it with Ha, if you can't flat it away there's little you can do. Personally I would suggest ditching it and getting another camera.
- The Sun?
- Has thanked: 4 times
Re: ZWO 183
Thanks for your answer, but I do not think it is the Moiré effect, it is only in the lower part of the image and they are large quarters, not compatible with the Moiré effect.rsfoto wrote: ↑Wed Mar 10, 2021 5:20 pm Hi,
- The Sun?
Re: ZWO 183
marktownley wrote: ↑Wed Mar 10, 2021 8:58 pm Hi there and welcome to the forum!
Hello, which camera would you recommend?
Re: ZWO 183
https://astronomy.tools/calculators/field_of_view/ is the tool to use to get the best idea of what you want to do for Solar etc., imaging.
You will need to fill in the various options that you either have or want to try-out with any particular camera to see on screen the different results that any specific camera will produce. An immediate comparison with all the options will or can remain on screen to show the differences.
Re: ZWO 183
Hi,Duckbig wrote: ↑Thu Mar 11, 2021 12:27 pmThanks for your answer, but I do not think it is the Moiré effect, it is only in the lower part of the image and they are large quarters, not compatible with the Moiré effect.rsfoto wrote: ↑Wed Mar 10, 2021 5:20 pm Hi,
OK, was just an idea ...
- Has thanked: 174 times
- Been thanked: 619 times
Re: ZWO 183
I had to return the ASI 183 to ZWO due to bad fixed pattern noise.
This is also seen in the ASI 178.
There’s a long thread on the subject on CN.
Re: ZWO 183
WOW, good to know. What does ZWO say to this problem ?
Re: ZWO 183
They now say on their website that the ASI 183 is not recommended for Ha solar imaging..
