Hi all,
A G1 geomagnetic storm arrived in the late hours of March 13th UTC and had a significant impact on magnetometers such as my own here in the UK. The cause was an uptick in the solar wind speed to over 550 km/s coupled with an oscillating positive/negative interplanetary magnetic field (Bz). The storm was preceded by geomagnetic unrest, also resulting from negative Bz, but with significantly slower wind speeds of around 350 km/s.
Thanks for looking.
G1 Geomagnetic Storm 13th March 2021
- Has thanked: 8588 times
- Been thanked: 8324 times
- JochenM
- Been thanked: 1619 times
- Has thanked: 18105 times
- Been thanked: 8941 times
Re: G1 Geomagnetic Storm 13th March 2021
Wow!! that's a fantastic graph, I bet you get excited when the computer shows you something like that Can you get you computer to alert you when levels get to a certain rate so that you have an early warning system?
- Has thanked: 9823 times
- Been thanked: 5826 times
Very interesting and I guess a pure coincidence as Yesterday I finished my round 68 around the Sun and the peak was approximately at the time I was born ...
- Has thanked: 65 times
- Been thanked: 4460 times
I really like these observations Stuart...so much more to monitor than the visible Sun
- Has thanked: 20955 times
- Been thanked: 10589 times
Excellent data Stu! we are around equinox time again with the Russell - McPherron effect kicking in. Be interesting to see your record of it in the weeks ahead and how compares to the (relative) lull either side.
