I am looking for the transmission characteristics of the red glass which is in front of the etalon assembly of my Lunt 50 pressure tuning module but I couldn't find anything, I suppose it is an internal ERF or something like that. I wonder if I can use the PT module without this red glass when there is already a Baader D-ERF placed in front of my Lunt-modified scope.
Thanks for any suggestion.
Red glass inside Lunt LS50THa
- krakatoa1883
- Has thanked: 153 times
- Been thanked: 496 times
- redglass.jpg (64.14 KiB) Viewed 2593 times
Raf
- Has thanked: 9411 times
- Been thanked: 5570 times
Re: Red glass inside Lunt LS50THa
I do not know anything about the Lunt solar scopes.
Do you refer to the first big glass held by those 2 screws ?
I have a double stacked SM 60 Coronado and normally each etalon comes with its own ERF and one day I thought. If the front mounted etalon already has an ERF why should I ahve a second one and so I decided to just take out the inner one and make a test with my camera and the result was a bit more contrast.
So my Logic tell me that if you have an ERF already at the entrance of the scope for what another inside ? It just steels luminance ...
IMHO
IMHO
- Bob Yoesle
- Has thanked: 540 times
- Been thanked: 807 times
This is most likely a RG630 filter which blocks UV, with an IR reflecting dielectric coating.
It probably can be removed and used safely with a Bader DERF. You still likely will have another RG630 filter in the Lunt blocking filter.
- Has thanked: 20435 times
- Been thanked: 10245 times
It is RG630
- krakatoa1883
Thank you very much for your answers, my concern was about not to damage the etalon.
Raf
- Has thanked: 173 times
- Been thanked: 615 times
With the high transmission of this filter, I feel there is little to be gained from its removal.
- krakatoa1883
Agree, want to remove it because is mounted in a barrel slightly larger than 2" that can't be inserted in the 2" focuser of the receiving scope and therefore requires an extension, this put the etalon in the wrong position. If I remove the barrel I can solve the problem.
Raf
Simples then - just remove it
- The Sun?
Thanks for your suggestion.rsfoto wrote: ↑Fri Apr 09, 2021 4:27 pm Hi,
IMHO
