ImPPG version 0.6.3
- GreatAttractor
- Has thanked: 747 times
- Been thanked: 753 times
ImPPG version 0.6.3
Download from: https://github.com/GreatAttractor/imppg ... tag/v0.6.3
Enhancements:
- Opening an image file by dragging and dropping onto the ImPPG window
Bug fixes:
- Crash when batch processing in CPU mode with deringing enabled
Enhancements:
Bug fixes:
- Has thanked: 8352 times
- Been thanked: 8103 times
Re: ImPPG version 0.6.3
Many thanks for all your great work developing this software.
It really is very much appreciated.
- Been thanked: 4908 times
Also thanks from me for your efforts in developing this version.
I hope to start using it soon.
Best Wishes
Best Wishes
- Been thanked: 2702 times
A big thanks for this very nice software !
Christian
Christian
- Has thanked: 17521 times
- Been thanked: 8763 times
- Has thanked: 1142 times
- Been thanked: 1329 times
Huge thanks for keeping this going, great software, the GPU optimization was such a huge leap!
- Rusted
- Has thanked: 7954 times
- Been thanked: 1937 times
A huge thank you from me as well.
ImPPG is the only software which will save the day in poor seeing conditions.
Today was a perfect example: Same image: Before and after ImPPG:
Thank you Chris and I will now try my latest of the same regions as yours, to see what it does for me..
Ok a few minutes later than my previous here - with a basic-start to a posted-image since redone with imppg and for a start is a welcome improvement.
Will do more trials with any different settings available in imppg.
Thanks for the reminder Chris and of course Filip/GreatAttractor - Thanks Very Much.
- imppg-2.jpg (75.93 KiB) Viewed 3154 times
- 26-4-2021 1609z TV2.5x 200frames AR2018-2021.jpg (52.34 KiB) Viewed 3154 times
- Rusted
Your ImPPG version is over-sharpened. Leading to uniform and unnatural artefacts.
ImPPG should ideally be used just after your stacking software.
Thank you Chris and yes this was done in a hurry and is still in the leaning and experimental stage of use.
Last night was a very-busy time for me with lots to do's...
- Radon86
- Has thanked: 745 times
- Been thanked: 660 times
Hi Filip,GreatAttractor wrote: ↑Thu Apr 15, 2021 7:21 pm Download from: https://github.com/GreatAttractor/imppg ... tag/v0.6.3
Enhancements:
Bug fixes:
Thanks for the great work on this software.
I just wonder about the following things.
1) Can you specify LRD separately from unsharp masking ? I mean I would like to do one with out necessarily doing the other.
2) Can you include a histogram display feature ? I think having a histogram would be advantageous. I hope you can do this for the next update !!
Thank you.
Magnus
Cameras: ASI120mm-S,ASI174mm
Accessory: SW Auto-focuser
- GreatAttractor
Done and doneBoso36 wrote: ↑Tue May 04, 2021 2:50 pm 1) Can you specify LRD separately from unsharp masking ? I mean I would like to do one with out necessarily doing the other.
1) Both can be disabled independently. To disable L-R deconvolution, set the number of iterations to 0 (or just click the "disable" button). To disable unsharp masking, set the "amount" to 1.0 (values > 1.0 sharpen, values < 1.0 blur), or just click "reset".
2) Histogram (of the current selection) is displayed in the background of the tone curve window. It applies to the image after all processing steps BEFORE the tone curve application.
- Radon86
Thank you Filip,GreatAttractor wrote: ↑Tue May 04, 2021 3:36 pmDone and doneBoso36 wrote: ↑Tue May 04, 2021 2:50 pm 1) Can you specify LRD separately from unsharp masking ? I mean I would like to do one with out necessarily doing the other.
I shall have to read the manual again for ImPPG.
On another note, the Tone Curve editor seems to have disappeared. How do you get it back ? It happened before a long time ago now.
Many thanks.
Magnus
- Radon86
Hi Filip,
I found the Tone Editor reset window position command.
I will have to learn ImPPG again now !!
Magnus
Magnus
