May 1st - Ha Sun
- Been thanked: 4340 times
May 1st - Ha Sun
Good day everyone...
The weather forecast was spot on yesterday...a sunny morning, cloudy afternoon, and evening showers. Recent rains have made the fields too wet to do much farming so I was able to work from home and got a bit of a solar fix too. Seeing degraded rapidly as morning waned, but I'm happy with the results.
The first image is a composite full disk using separate disk and limb exposures, taken through the LS80T/LS75FHa/B1800Ha and ASI174MM camera. The first image has the limb inverted, whole the colourized image has both parts displayed as positive views: The string of dark filaments in the south was the most noticeable feature to my eye, but the large prominence in the NE made a much better show with the camera. In my mind, I think we have been have many of these large polar filament bands in recent months...anyone else feel the same?
I settled on the ASI290 to image with the modded DS CR-150 OTA in order not to push the image scale in the seeing I had. I finally got the SSM setup (but not configured to use in FireCapture) and the best readings were in the 1.5-2 range, but the majority of the reading were 4-6.
The departing trio of AR's 2818/2820/2821 are shown in the image below: I created a 6 frame mosaic of the filament band...the variable conditions are visible in the variation between frames but it still came out well enough: There was one small spot of activity in the north near mid disk...not a lot of detail but maybe it will develop into something more: The final images try to highligh the proms. First pair is the is the big prom on the NE limb, and the last image is the small prom on the SE limb near the AR's: That's all from Saturday...it looks like we need some new activity to roll into view again
As always, questions and comments are always welcome.
Re: May 1st - Ha Sun
Thanks Terry
- Has thanked: 20435 times
- Been thanked: 10245 times
You got a really nice set here Brian. Glad the weather is being good for you for solar, even if it's not good for work...
Thanks Mark
Our weather has been completely screwy of late. We had snow Friday evening and it was -5 or so Friday night, so Saturday morning imaging still required a winter coat
- JochenM
- Been thanked: 1619 times
Good to hear you managed to get a session in, Brian.
Nice set of images. Particularly like the big prom; nice detail in that one.
- Been thanked: 4786 times
- Ivan
- Has thanked: 3465 times
- Been thanked: 2250 times
Jochen, Maurits, and Ivan...
Thanks for your feedback on the images...always appreciated
- Been thanked: 16694 times
Very nice work Brian. I absolutely love the second colored full disc image. I never could visually see the large faint prom in the NE with my SMII60.
- Has thanked: 9144 times
- Been thanked: 6025 times
A beautiful set, Brian. The long prom stands out from the full disk images, specially the color one: what a beautiful sight ! Glad you caught it.
- Been thanked: 4904 times
- Been thanked: 8789 times
Wow!! I really love the second full disc, the prom in the north has really changed since I viewed it early afternoon here. It looks like it was lifting off. A great set
The weather here has been very dry for over a month and very cold too. Today the weather has broken with a huge storm, the wind is howling and rain coming down in horizontal sheets all day. A perfect English bank holiday Monday
James, Franco, Eric, and Alexandra...
Thanks for all your comments and feedback on the session...always appreciated
Also a big thanks for the full disk image being chosen as the photo of the day...nice to see that others like it too
