Kaleimera,
Have a wonderful day all
Sundogs on 7/5/21
Moderator: Montana
- marios i.
- Has thanked: 1707 times
- Been thanked: 1125 times
Sundogs on 7/5/21
Marios S.Ioannou
Sketcher/Visual Observer
- Radon86
- Has thanked: 763 times
- Been thanked: 663 times
Re: Sundogs on 7/5/21
Hi, can you please enlighten me, not sure what is going on in this photo ? Is this an atmospheric effect of the sun on the clouds ?
Magnus
Magnus
Cameras: ASI120mm-S,ASI174mm
Accessory: SW Auto-focuser
I can reply Magnus, that it and rainbows are somewhat similar, but in this case of Sun-Bow/Sun-Dogs are due to to upper-air levels usually containing ice-crystals which themselves refract the Sun's light.
Similar effect can of course be obtained at ground-level by using a spray from a hose-pipe away from the Sun's light to perform your own rainbow,
but not so much as Sun-Dogs - which are obviously much higher in the sky surrounding the Sun.
Great fun if you don't mind getting damp too...
https://en.wikipedia.org/wiki/Sun_dog
ps I've tried flying light-aircraft through rainbows, but it is actually impossible to achieve...
- Has thanked: 18105 times
- Been thanked: 8942 times
Fantastic image Marios, I zoomed in to see what the little UFO is, is it a bird?
- JochenM
- Been thanked: 1619 times
- Has thanked: 65 times
- Been thanked: 4462 times
Nice shot Marios!!!
- Has thanked: 9823 times
- Been thanked: 5828 times
Hi Marios,
Nice nice nice
Well done.
Nice nice nice
Well done.
