Actually the outer case seems to have excellent heat conductivity. Even at delta T -15 degree under ambient, I am just measuring about under 1 *C in disperancy from the front and the back( even smaller if I keep the delta T lower) And since the etalon does not directly screwed into the outer case I think it wont introduce too much heat gradient into the etalon.
Any suggestion for a DIY Quark active cooler?
- minhlead
- Has thanked: 739 times
- Been thanked: 1107 times
Re: Any suggestion for a DIY Quark active cooler?
Minh.
Loves from Viet Nam <3
My gear:
Mount: JTW Tridents GTR
Camera:
PlayerOne Apollo M-Max
My gear:
Camera:
- Been thanked: 2725 times
It looks good !
- minhlead
Thanks Christian,
I still wanna do some testing with tilting as a 2 pronged approach to the tuning and see what works best.
Minh.
My gear:
Camera:
My gear:
Camera:
- Has thanked: 20813 times
- Been thanked: 10487 times
Looks good!
- minhlead
Thanks Mark,
Hope it works. If it does I'll make a 3d printed case for better mounting mechanism
Minh.
My gear:
Camera:
My gear:
Camera:
- Has thanked: 3317 times
- Been thanked: 1907 times
When RodAstro took the retaining screw out of the joint between the red bit and the black barlow/combo that the joint is not screwed up tight.
There are a series of holes for the screw so its unlikely to be screwed up tight.
So the pressure of the tie downs will be tilting the joint I presume.
The screw is a imperial torq security one I think being USA.
Cheers. Andrew.
Cheers. Andrew.
- minhlead
Thanks Andy, I worried the same thing too. But i tried to flex the joint between the black telecentric barlow and the red outer case but it seems solid to me, no flexing. And when I make the radiator I already take this joint into account, the tie down and the radiator actually both applying pressure to the black telecentric (the radiator extends about 5mm and seats partly on the telecentric barlow) , the tie-down on the 1.25 inches eyepiece drawer is fixed lightly.AndiesHandyHandies wrote: ↑Fri May 21, 2021 7:58 am Hi
Cheers. Andrew.
Minh.
My gear:
Camera:
My gear:
Camera:
- minhlead
Okay so the cooler works very well. Brings the temperature down about -12*C.
Minh.
My gear:
Camera:
My gear:
Camera:
Good job!
- minhlead
Maybe I should patent it. "An apparatus for cooling optical filter". Sounds good )
Minh.
My gear:
Camera:
My gear:
Camera:
You should sell the patent to DayStar ;-)
- minhlead
They'd be first on the list )
Minh.
My gear:
Camera:
My gear:
Camera:
